Is it me or did there used to be link’s here to download the firmware? Need to Flash from MPCNC to LR4 and can’t see to find a link to DL the firmware for the SKR Board.
Thought you could click on the files here?
Neither of them are for the Lowrider, the Lowrider firmwares have LR in the name I believe.
That’s right, the 3DP firmware files are for the MP3DP printer.
The V1 firmware is at
Specifically the SKR Pro 1.2 LowRider Dual endstop firmware is at:
https://github.com/V1EngineeringInc/MarlinBuilder/releases/download/515/V1CNC_SkrPro_DualLR_2209-2.1.1.zip
Thank you Very MUCH! Firmware Uploaded.
Is there a command to see if you have the right firmware loaded. All of my Axis work but Y2 and Z2. I double checked the wirring and same issue.
Test by swapping the drivers to see if the problem persists or it moves to another axis, turn off the board before you do that.
Good suggestion, if I move the Z to the other Z, it works… So there is something wrong with the output on Y and Z max
If I move Zmax to Zmin position on SKR board it works… So for some reason Z2 is not sending any thing out. I confirmed that I flashed the firmware (firmware.cur) was on the SD card after flashing. Will try and re-flash tonight…
Next try connecting z2 wiring to z1 driver and check if it moves, if it does there’s something wring with your board
Will give it a try tonight.
