Levelers for table
I noticed that my LowRider table wasn’t perfectly level. It’s in the basement where the floor isn’t level. So I designed and 3D printed some levelers that go on the legs of the table. I’m hoping this will help make my cuts slightly more accurate. The levelers use 5/16" bolts and lock nuts.
I like how large the feet are. Are these on printables or available elsewhere?
Great build! and as @Phelan said the large feet are great!
depends on your table. If you table flexes with the legs yes it will. If not it won’t add a ton of accuracy. are you having a accuracy problem?
