Guys,
I’ve purchased just about everything that I need to build my leo laser add on. Is the documentation on the website current, and will the latest dual end stop firmware support it?
Guys,
I’m not sure what a “leo laser” is. As for firmware support, the last I saw on the forum, laser was enabled on the Rambo firmware and the SKR Pro firmware, but it was not enabled for other boards. I believe it was enabled in version 509 (current version is 510). If you don’t have one of these two boards, you can do a diff between the configuration.h and configuration_adv.h of the Rambo version of Marlin and your version of Marlin to see the differences.
Ryan outlines his laser testing and provides a test g-code file in this topic.
The Leo Laser is Ryan’s recommended budget laser:
Leo did a very good job with that and I trust he tried very hard to make it future proof. But it was a few years ago. I haven’t heard much about it. There are some very inexpensive banggood lasers out now that have made it easier to just buy them.
@vicious1, should we update the docs, or do you still think it is worth it over the cheapo imports?
Hmmm, yeah, I think moving that DOC would be best. I don’t want to remove it though. I think it still has value.
I have everything for the leo laser, but in the interest of ease and laziness, should I pursue one from aliexpress already to roll?
No, I would finish up the Leo. Mine has been great, it is pretty good quality and I even have a few different lenses. Good to see how they work.
Thanks brother!
I’m setting up my laser(finally) and I have a few questions.
When setting up the driver, I was able to set up voltage easily, but when backing down the current adjust, I was not able to lower it to the point that the LED went out.
There are 2 - 12v DC power input spots on the wye driver board. One is a jst connector, and the other looks like a barrel connector. Will either work, or do I need power to both? I powered both and now my RAMBO stopped working…
Help!
Hi Jarrod,
Are you still trying to sort this laser out?
I just got my Leo laser working a couple of days ago so I can answer a couple of your questions,
I hope that helps!
