Hello!
I have a working MPCNC with a 12”x12” working area. I have made a couple of cool things with it and its Makita clone router, but it is just so dang loud in operation I just always talk myself out of using it. Then my kids got me a 5W diode laser on a gantry, 8”x8” working area, and using that plus Lightburn has been a ton of fun. The only issue with it is the size and it has a practical limit of about 3mm thick plywood with 10 passes.
So it seems like I can solve all my problems by buying one of those 24W JTech lasers and making my MPCNC bigger! (I have smoke extraction figured out for all combinations, so leaving that out of the discussion for now. I know I’ll need to design the right eye shielding around the machine in addition to the goggles, but I’ve done this before and will have a safe setup before applying any laser power.)
My question is this: I want my standard workpiece size to be 2’x4’x1/4” plywood. I will only be using a laser, never a router. I’ll be taking apart my MPCNC Primo, which uses the JackpotCNC board, the NEMA17s, endstops, all that stuff. My workshop is my garage, and I will be lifting the machine up (over the car) when not in use, so it will probably be mounted to a piece of plywood which will sit on sawhorses in operation (screwed or clamped). I have a P1S 3D printer, so no problem printing parts.
Should I make my MPCNC bigger, or should I make it a Lowrider V4 instead? I’ve read that that ~3ft is the point where the Lowrider becomes the better option, but that’s assuming a router, correct? Does the laser-only approach change anything? I searched for similar laser builds but I did not find anything that answered this question.
Thanks!
