Just a few picks to get the thread going, Super busy printing way to many parts and to much time overthinking. Been a great distraction back at the room to pass the time while on the road.
Hope to have both builds online and running in the next few weeks just in time to move into the new shop.
Will update with more pics when I get a free min.
Thanks again Ryan for the great project and awesome community that you have put together.
I have been less concerned with how exact the lengths are, My goal was to get them as close as I can and will make it up in assembly using measurements and a square.
Next project will be to design and cut an electronics enclosure.
Working on 2 different table designs.
Then final assembly.
I have been kinda milking this since I have been on the road a bunch, So at this point I have done a fantastic job of overthinking this project.
Project has taken a seat to work but is coming along, I hope to have more to share in the next week or two.
I decided to turn around the connectors for the limit switches and found that they are not symmetrical so I had to reprint the motor shield covers to make them fit.
The stainless I ordered I paid a too much for is also not as straight as I would like and have been working on a remedy.
So after some sabbatical, and a ton of life’s events and a new shop build I find myself back at it working on my MPCNC build here in Texas. Powered the electronics and tested motors last night and everything performed as expected, Today I need to wire the VFD and program it for the 800 watt spindle I chose for my application. RJ45 motor shields with fan control and limit switch feedback have also performed well and will need to be torture tested soon.
Once again I find myself with a nearly complete build and a new file set have been released, This time I will resist the urge to rebuild this machine a second time as I am quite happy with this Burly Edition at this point.
Well not the best of updates but progress is progress and I’m glade to finally be back at it.
I’m using 3/4 birch ply since its what I had laying around, I have some .220 acrylic I’m going to cut windows out of for the door. Not sure the gas struts or going to like the additional weight.
I printed the fan mounts posted by Memon on Thingiverse and made some motor shields for the steppers and Rambo board, So now I’m using just 5 ethernet cables to run all my cooling fans, limit switches and stepper motors.
Wanted to simplify and make wiring my MPCNC and Lowrider, clean and easy but I think at this point the solution was overengineered for 2 tables, lol.
The boards use all standard 2.54 mm pin spacing so that almost any type of connector can be used, I chose to use Phoenix Contac push/release terminal’s, But you could use header pins or screw terminals all the same and a standard rj45 terminal I have both top insert and side insert boards depending on location on the machine.
The cable is Shielded CAT6 24awg, They are a bit stiff but the cable chain keeps them from wandering or flexing the connectors.
The dual row of header pins on the Rambo shield allows me to route the limit switch signals to the right inputs on the Rambo or I can just use the pins to inject power to the fans
