Joebus
(Joe Mathiau)
February 21, 2024, 2:12pm
1
I’m looking for a little hand holding I need a refresher/walkthrough of starting a job on my LR3 with a jackpot and probe. I use F360 to create my gcode.
It’s been almost 2 years since I’ve run my LR2 and have just finished the LR3. I’m very rusty. I have drawn the crown test and passed.
I’ve uploaded my gcode to the LR3. My 0,0 of my spoil board is 80mm from home on my X.
*I want to be able to hit “start job” > Press button to probe > Probe > remove probe > turn on router > Press button to start cutting and motion.
In Fusion PP I have “Probe on Start” turned on. EDIT: Having this turned on is giving me an error when starting the job.
I know there is some Start and End gcode that is provided( saw in jackpot docs) . Where do these go and how do I use them?
DougJoseph
(Doug Joseph (design8studio))
February 21, 2024, 2:50pm
2
So you can definitely use Fusion 360 to produce Gcode. Most of us use ESTLcam instead for most jobs. I use ESTLCam for my LowRider that has a router, but I use Fusion 360 for my LowRider that has a plasma cutter.
Getting setup in ESTLcam is pretty straightforward and pretty easy. In its options/preferences/setup area it has boxes where you paste in your Start Gcode and End GCode. It has some basic settings, such as choosing GRBL (for Jackpot) as opposed to choosing Marlin (for SKR boards). ESTLcam basically builds its own Post Processor for you on the fly based on the settings you choose.
Things are a little different with Fusion 360. I think it needs you to choose or provide a Post Processor, and you also will need to walk though some setup steps per job. I was able to locate a Post Processor for my plasma related work, but I don’t know about one for what you are doing.
One workaround option (perhaps temporary) is to put your starting GCode and ending GCode in files (.gcode files) on your SD card and run them like jobs. Or to put them in .g files and upload them to the Jackpot and assign macro buttons to point to them.
In the FluidNC WebUI for the Jackpot, there is a setting that turns on a Probe panel (not enabled by default). It adds a probe interface to the WebUI.
Joebus
(Joe Mathiau)
February 21, 2024, 2:56pm
3
Hi Doug, thanks for the speedy reply!
I’ve already got the PP for fusion in and that is actually working(except for the probe at start line, this used to work on my LR2 but doesn’t now). I also have probe menu enabled and have been probing successfully from the webui and from the M5 dial. I think what I’m still struggling on is order of operations/workflow.
So I think for now I need to : Jog to my start location on XY > Zero Location > Probe > Zero Location > Jog up Z away from workpiece > Remove Probe > Start Router > Start Job > Wait and Pray > Profit??
DougJoseph
February 21, 2024, 3:02pm
4
Basically, yes. A couple thoughts come to mind here.
One is do an “air cut” first as a test. To do this, when you probe, manually tap your electrode wire end against your touch plate, well before the machine actually moves all the way down. This falsely and intentionally tells the machine the material is higher than it is. You can then run the job, without the router on, in a nondestructive test.
The other is that, depending on your GCode settings, the script for probing may or may not automatically set an XY 0,0 offset. The probe feature built into the FluidDial pendant does not. The probe scripts offered by some V1E docs do. By contrast, however, in practically all cases where you specify a plate thickness in probe settings, or probe script, the probe action will automatically set the Z height at zero offset at the time of probing.
Does this help?
Joebus
(Joe Mathiau)
February 21, 2024, 3:34pm
5
Yes thank you. This helps. I like your tip for setting the probe higher for testing.
Joebus
(Joe Mathiau)
February 21, 2024, 5:56pm
6
Ok so I’ve been able to get things to start and run. The motions are matching what I’m telling it to do. All except it runs 600 mm up the Y axis then starts. X is spot on and Y is spot on. Any ideas?
DougJoseph
February 21, 2024, 6:21pm
7
Maybe you could wrap your GCode file as a Zip compressed file and upload it here. ?
Joebus
(Joe Mathiau)
February 21, 2024, 6:22pm
8
Yes, Sorry I just realized I should share gcode and some pics. one min
All they Y axis movements look normal to me.
Summary
(Fusion CAM 2.0.18441)
( Posts processor: MPCNC.cps)
( Gcode generated: Wednesday, February 21, 2024 5:42:30 PM GMT)
( Document: Untitled)
( Setup: Setup1)
( Ranges Table:)
( X: Min=-21.546 Max=1240.746 Size=1262.292)
( Y: Min=5.149 Max=2426.157 Size=2421.008)
( Z: Min=-1 Max=15 Size=16)
( Tools Table:)
( T1 D=25.4 CR=0 - ZMIN=-1 - face mill )
( Feedrate and Scaling Properties:)
( Feed: Travel speed X/Y = 2500)
( Feed: Travel Speed Z = 300)
( Feed: Enforce Feedrate = true)
( Feed: Scale Feedrate = false)
( Feed: Max XY Cut Speed = 900)
( Feed: Max Z Cut Speed = 180)
( Feed: Max Toolpath Speed = 1000)
( G1->G0 Mapping Properties:)
( Map: First G1 → G0 Rapid = false)
( Map: G1s → G0 Rapids = false)
( Map: SafeZ Mode = Retract : default = 15)
( Map: Allow Rapid Z = false)
( *** START begin ***)
G90
G94
G17
G21
( *** START end ***)
( *** SECTION begin ***)
( X Min: -21.546 - X Max: 1240.746)
( Y Min: 5.149 - Y Max: 2426.157)
( Z Min: -1 - Z Max: 15)
( Face2 - Milling - Tool: 1 - face mill)
( COMMAND_START_SPINDLE)
( COMMAND_SPINDLE_CLOCKWISE)
( >>> Spindle Speed 5000)
M3 S5000
( COMMAND_COOLANT_ON)
G0 Z15 F300
X1235.71 Y5.149 F2500
Z5 F300
( MOVEMENT_PLUNGE)
G1 Z2.04 F667
( MOVEMENT_LEAD_IN)
G18 G3 X1233.17 Z-0.5 I-2.54 F2000
G1 X1231.91 F2000
( MOVEMENT_CUTTING)
X-12.71 F2000
( MOVEMENT_LINK_TRANSITION)
G17 G2 Y22.821 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X1231.91 F2000
G3 Y40.493 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X-12.71 F2000
G2 Y58.164 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X1231.91 F2000
G3 Y75.836 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X-12.71 F2000
G2 Y93.507 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X1231.91 F2000
G3 Y111.179 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X-12.71 F2000
G2 Y128.851 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X1231.91 F2000
G3 Y146.522 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X-12.71 F2000
G2 Y164.194 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X1231.91 F2000
G3 Y181.865 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X-12.71 F2000
G2 Y199.537 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X1231.91 F2000
G3 Y217.208 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X-12.71 F2000
G2 Y234.88 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X1231.91 F2000
G3 Y252.552 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X-12.71 F2000
G2 Y270.223 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X1231.91 F2000
G3 Y287.895 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X-12.71 F2000
G2 Y305.566 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X1231.91 F2000
G3 Y323.238 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X-12.71 F2000
G2 Y340.91 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X1231.91 F2000
G3 Y358.581 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X-12.71 F2000
G2 Y376.253 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X1231.91 F2000
G3 Y393.924 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X-12.71 F2000
G2 Y411.596 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X1231.91 F2000
G3 Y429.268 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X-12.71 F2000
G2 Y446.939 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X1231.91 F2000
G3 Y464.611 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X-12.71 F2000
G2 Y482.282 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X1231.91 F2000
G3 Y499.954 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X-12.71 F2000
G2 Y517.625 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X1231.91 F2000
G3 Y535.297 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X-12.71 F2000
G2 Y552.969 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X1231.91 F2000
G3 Y570.64 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X-12.71 F2000
G2 Y588.312 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X1231.91 F2000
G3 Y605.983 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X-12.71 F2000
G2 Y623.655 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X1231.91 F2000
G3 Y641.327 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X-12.71 F2000
G2 Y658.998 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X1231.91 F2000
G3 Y676.67 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X-12.71 F2000
G2 Y694.341 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X1231.91 F2000
G3 Y712.013 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X-12.71 F2000
G2 Y729.685 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X1231.91 F2000
G3 Y747.356 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X-12.71 F2000
G2 Y765.028 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X1231.91 F2000
G3 Y782.699 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X-12.71 F2000
G2 Y800.371 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X1231.91 F2000
G3 Y818.043 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X-12.71 F2000
G2 Y835.714 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X1231.91 F2000
G3 Y853.386 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X-12.71 F2000
G2 Y871.057 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X1231.91 F2000
G3 Y888.729 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X-12.71 F2000
G2 Y906.4 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X1231.91 F2000
G3 Y924.072 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X-12.71 F2000
G2 Y941.744 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X1231.91 F2000
G3 Y959.415 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X-12.71 F2000
G2 Y977.087 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X1231.91 F2000
G3 Y994.758 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X-12.71 F2000
G2 Y1012.43 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X1231.91 F2000
G3 Y1030.102 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X-12.71 F2000
G2 Y1047.773 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X1231.91 F2000
G3 Y1065.445 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X-12.71 F2000
G2 Y1083.116 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X1231.91 F2000
G3 Y1100.788 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X-12.71 F2000
G2 Y1118.46 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X1231.91 F2000
G3 Y1136.131 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X-12.71 F2000
G2 Y1153.803 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X1231.91 F2000
G3 Y1171.474 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X-12.71 F2000
G2 Y1189.146 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X1231.91 F2000
G3 Y1206.818 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X-12.71 F2000
G2 Y1224.489 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X1231.91 F2000
G3 Y1242.161 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X-12.71 F2000
G2 Y1259.832 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X1231.91 F2000
G3 Y1277.504 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X-12.71 F2000
G2 Y1295.175 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X1231.91 F2000
G3 Y1312.847 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X-12.71 F2000
G2 Y1330.519 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X1231.91 F2000
G3 Y1348.19 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X-12.71 F2000
G2 Y1365.862 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X1231.91 F2000
G3 Y1383.533 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X-12.71 F2000
G2 Y1401.205 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X1231.91 F2000
G3 Y1418.877 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X-12.71 F2000
G2 Y1436.548 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X1231.91 F2000
G3 Y1454.22 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X-12.71 F2000
G2 Y1471.891 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X1231.91 F2000
G3 Y1489.563 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X-12.71 F2000
G2 Y1507.234 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X1231.91 F2000
G3 Y1524.906 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X-12.71 F2000
G2 Y1542.578 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X1231.91 F2000
G3 Y1560.249 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X-12.71 F2000
G2 Y1577.921 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X1231.91 F2000
G3 Y1595.593 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X-12.71 F2000
G2 Y1613.264 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X1231.91 F2000
G3 Y1630.936 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X-12.71 F2000
G2 Y1648.607 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X1231.91 F2000
G3 Y1666.279 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X-12.71 F2000
G2 Y1683.95 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X1231.91 F2000
G3 Y1701.622 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X-12.71 F2000
G2 Y1719.294 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X1231.91 F2000
G3 Y1736.965 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X-12.71 F2000
G2 Y1754.637 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X1231.91 F2000
G3 Y1772.308 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X-12.71 F2000
G2 Y1789.98 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X1231.91 F2000
G3 Y1807.652 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X-12.71 F2000
G2 Y1825.323 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X1231.91 F2000
G3 Y1842.995 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X-12.71 F2000
G2 Y1860.666 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X1231.91 F2000
G3 Y1878.338 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X-12.71 F2000
G2 Y1896.01 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X1231.91 F2000
G3 Y1913.681 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X-12.71 F2000
G2 Y1931.353 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X1231.91 F2000
G3 Y1949.024 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X-12.71 F2000
G2 Y1966.696 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X1231.91 F2000
G3 Y1984.367 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X-12.71 F2000
G2 Y2002.039 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X1231.91 F2000
G3 Y2019.711 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X-12.71 F2000
G2 Y2037.382 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X1231.91 F2000
G3 Y2055.054 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X-12.71 F2000
G2 Y2072.725 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X1231.91 F2000
G3 Y2090.397 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X-12.71 F2000
G2 Y2108.069 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X1231.91 F2000
G3 Y2125.74 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X-12.71 F2000
G2 Y2143.412 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X1231.91 F2000
G3 Y2161.083 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X-12.71 F2000
G2 Y2178.755 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X1231.91 F2000
G3 Y2196.427 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X-12.71 F2000
G2 Y2214.098 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X1231.91 F2000
G3 Y2231.77 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X-12.71 F2000
G2 Y2249.441 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X1231.91 F2000
G3 Y2267.113 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X-12.71 F2000
G2 Y2284.784 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X1231.91 F2000
G3 Y2302.456 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X-12.71 F2000
G2 Y2320.128 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X1231.91 F2000
G3 Y2337.799 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X-12.71 F2000
G2 Y2355.471 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X1231.91 F2000
G3 Y2373.142 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X-12.71 F2000
G2 Y2390.814 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X1231.91 F2000
G3 Y2408.486 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X-12.71 F2000
G2 Y2426.157 J8.836 F2000
( MOVEMENT_CUTTING)
G1 X1231.91 F2000
( MOVEMENT_LEAD_OUT)
G18 G2 X1234.45 Z2.04 K2.54 F2000
( MOVEMENT_RAPID)
G0 Z5 F300
( MOVEMENT_PLUNGE)
G1 Z1.54 F667
( MOVEMENT_LEAD_IN)
G3 X1233.17 Z-1 I-2.54 F2000
G1 X1231.91 F2000
( MOVEMENT_FINISH_CUTTING)
X-12.71 F2000
G1 X1231.91 F2000
G1 X-12.71 F2000
G1 X1231.91 F2000
G1 X-12.71 F2000
G1 X1231.91 F2000
G1 X-12.71 F2000
G1 X1231.91 F2000
G1 X-12.71 F2000
G1 X1231.91 F2000
G1 X-12.71 F2000
G1 X1231.91 F2000
G1 X-12.71 F2000
G1 X1231.91 F2000
G1 X-12.71 F2000
G1 X1231.91 F2000
G1 X-12.71 F2000
G1 X1231.91 F2000
G1 X-12.71 F2000
G1 X1231.91 F2000
G1 X-12.71 F2000
G1 X1231.91 F2000
G1 X-12.71 F2000
G1 X1231.91 F2000
G1 X-12.71 F2000
G1 X1231.91 F2000
G1 X-12.71 F2000
G1 X1231.91 F2000
G1 X-12.71 F2000
G1 X1231.91 F2000
G1 X-12.71 F2000
G1 X1231.91 F2000
G1 X-12.71 F2000
G1 X1231.91 F2000
G1 X-12.71 F2000
G1 X1231.91 F2000
G1 X-12.71 F2000
G1 X1231.91 F2000
G1 X-12.71 F2000
G1 X1231.91 F2000
G1 X-12.71 F2000
G1 X1231.91 F2000
G1 X-12.71 F2000
G1 X1231.91 F2000
G1 X-12.71 F2000
G1 X1231.91 F2000
G1 X-12.71 F2000
G1 X1231.91 F2000
G1 X-12.71 F2000
G1 X1231.91 F2000
G1 X-12.71 F2000
G1 X1231.91 F2000
G1 X-12.71 F2000
G1 X1231.91 F2000
G1 X-12.71 F2000
G1 X1231.91 F2000
G1 X-12.71 F2000
G1 X1231.91 F2000
G1 X-12.71 F2000
G1 X1231.91 F2000
G1 X-12.71 F2000
G1 X1231.91 F2000
G1 X-12.71 F2000
G1 X1231.91 F2000
G1 X-12.71 F2000
G1 X1231.91 F2000
G1 X-12.71 F2000
G1 X1231.91 F2000
G1 X-12.71 F2000
G1 X1231.91 F2000
G1 X-12.71 F2000
G1 X1231.91 F2000
G1 X-12.71 F2000
G1 X1231.91 F2000
G1 X-12.71 F2000
G1 X1231.91 F2000
G1 X-12.71 F2000
G1 X1231.91 F2000
G1 X-12.71 F2000
G1 X1231.91 F2000
G1 X-12.71 F2000
G1 X1231.91 F2000
G1 X-12.71 F2000
G1 X1231.91 F2000
G1 X-12.71 F2000
G1 X1231.91 F2000
G1 X-12.71 F2000
G1 X1231.91 F2000
G1 X-12.71 F2000
G1 X1231.91 F2000
G1 X-12.71 F2000
G1 X1231.91 F2000
G1 X-12.71 F2000
G1 X1231.91 F2000
G1 X-12.71 F2000
G1 X1231.91 F2000
G1 X-12.71 F2000
G1 X1231.91 F2000
G1 X-12.71 F2000
G1 X1231.91 F2000
G1 X-12.71 F2000
G1 X1231.91 F2000
G1 X-12.71 F2000
G1 X1231.91 F2000
G1 X-12.71 F2000
G1 X1231.91 F2000
G1 X-12.71 F2000
G1 X1231.91 F2000
G1 X-12.71 F2000
G1 X1231.91 F2000
G1 X-12.71 F2000
G1 X1231.91 F2000
G1 X-12.71 F2000
G1 X1231.91 F2000
G1 X-12.71 F2000
G1 X1231.91 F2000
G1 X-12.71 F2000
G1 X1231.91 F2000
G1 X-12.71 F2000
G1 X1231.91 F2000
G1 X-12.71 F2000
G1 X1231.91 F2000
G1 X-12.71 F2000
G1 X1231.91 F2000
G1 X-12.71 F2000
G1 X1231.91 F2000
G1 X-12.71 F2000
G1 X1231.91 F2000
G1 X-12.71 F2000
G1 X1231.91 F2000
G1 X-12.71 F2000
G1 X1231.91 F2000
G1 X-12.71 F2000
G1 X1231.91 F2000
G1 X-12.71 F2000
G1 X1231.91 F2000
G1 X-12.71 F2000
G1 X1231.91 F2000
G18 G2 X1234.45 Z1.54 K2.54 F2000
( MOVEMENT_RAPID)
G0 Z15 F300
( *** SECTION end ***)
( *** STOP begin ***)
( COMMAND_COOLANT_OFF)
X0 Y0 F2500
( COMMAND_STOP_SPINDLE)
M5
M30
( *** STOP end ***)
Joebus
(Joe Mathiau)
February 21, 2024, 6:56pm
9
I think it has to do with the M5 Dial pendant. I’m doing my jogging, probing and job start via the dial. Referring back to the coordinate readout glitch in the dial; When I jog X over to where I need to be. Then switch to Y, Y displays a -600 and something readout. If I wait 1 sec it clears and goes to zero. When I started the job I posted above I jogged X over and did probe but never switched the dial to Y so I think it was stuck at -600 on Y. So then it traveled to “0” which in actuality is +600 up the Y. I’m testing now by doing everything the same but displaying Y on the dial for a second so it zeros out.
EDIT: Yes. This was the issue. It works as expected now.
DougJoseph
February 21, 2024, 7:05pm
10
OK, glad you got that sorted. Wow.
