Jackpot Wiring
Hi Everyone,
Excited to build my first zen! Not quite sure what the correct wiring is here, any pointers on connecting to the jackpot?
Here’s the config yaml (in case it helps).
board: Jackpot TMC2209
meta: 09-10-2024 RyanZ
planner_blocks: 32
stepping:
  engine: I2S_STATIC
  idle_ms: 255
  pulse_us: 4
  dir_delay_us: 1
  disable_delay_us: 0
uart1:
  txd_pin: gpio.0
  rxd_pin: gpio.4
  rts_pin: NO_PIN
  baud: 115200
  mode: 8N1
kinematics:
  corexy:
axes:
  shared_stepper_disable_pin: NO_PIN
  x:
    steps_per_mm: 50.000
    max_rate_mm_per_min: 9000.000
    acceleration_mm_per_sec2: 200.000
    max_travel_mm: 1220
    soft_limits: false
    homing:
      cycle: 2
      positive_direction: false
      mpos_mm: 0
      feed_mm_per_min: 300.000
      seek_mm_per_min: 1500.000
      settle_ms: 500
      seek_scaler: 1.100
      feed_scaler: 1.100
    #X
    motor0:
      limit_neg_pin: gpio.25:high
      limit_pos_pin: NO_PIN
      limit_all_pin: NO_PIN
      hard_limits: false
      pulloff_mm: 4.000
      tmc_2209:
        uart_num: 1
        addr: 0
        cs_pin: NO_PIN
        r_sense_ohms: 0.110
        run_amps: 0.800
        homing_amps: 0.800
        hold_amps: 0.500
        microsteps: 8
        stallguard: 0
        stallguard_debug: false
        toff_disable: 0
        toff_stealthchop: 5
        toff_coolstep: 3
        run_mode: StealthChop
        homing_mode: StealthChop
        use_enable: false
        direction_pin: I2SO.1
        step_pin: I2SO.2
        disable_pin: I2SO.0
  y:
    max_travel_mm: 2440
    soft_limits: false
    homing:
      cycle: 1
      mpos_mm: 0
      settle_ms: 500
      seek_scaler: 1.100
      feed_scaler: 1.100
    #Y
    motor0:
      limit_neg_pin: gpio.33:high
      hard_limits: false
      pulloff_mm: 4.000
      tmc_2209:
        uart_num: 1
        addr: 1
        cs_pin: NO_PIN
        r_sense_ohms: 0.110
        run_amps: 0.800
        homing_amps: 0.800
        hold_amps: 0.500
        microsteps: 8
        stallguard: 0
        toff_disable: 0
        toff_stealthchop: 5
        toff_coolstep: 3
        use_enable: false
        step_pin: I2SO.5
        direction_pin: I2SO.4
        disable_pin: I2SO.7
    #A
    #motor1:
   #   limit_neg_pin: gpio.35:high
   #   limit_pos_pin: NO_PIN
   #   limit_all_pin: NO_PIN
   #   hard_limits: false
   #   pulloff_mm: 4.000
   #   tmc_2209:
   #     uart_num: 1
   #     addr: 3
   #     cs_pin: i2so.14
   #     r_sense_ohms: 0.110
   #     run_amps: 0.800
   #     homing_amps: 0.800
   #     hold_amps: 0.500
   #     microsteps: 8
   #     stallguard: 0
   #     stallguard_debug: false
   #     toff_disable: 0
   #     toff_stealthchop: 5
   #     toff_coolstep: 3
   #     run_mode: StealthChop
   #     homing_mode: StealthChop
   #     use_enable: false
   #     step_pin: I2SO.13
   #     direction_pin: I2SO.12
   #     disable_pin: I2SO.15
  z:
    steps_per_mm: 200.000
    max_rate_mm_per_min: 1200.000
    max_travel_mm: 300.000
    soft_limits: false
    homing:
      cycle: 0
      positive_direction: true
      mpos_mm: 0
      seek_mm_per_min: 800.000
      settle_ms: 500
      seek_scaler: 1.100
      feed_scaler: 1.100
    motor0:
      limit_neg_pin: NO_PIN
      limit_pos_pin: gpio.32:high
      hard_limits: false
      pulloff_mm: 4.000
      tmc_2209:
        uart_num: 1
        addr: 2
        cs_pin: NO_PIN
        r_sense_ohms: 0.110
        run_amps: 0.800
        homing_amps: 0.800
        hold_amps: 0.500
        microsteps: 8
        stallguard: 0
        toff_disable: 0
        toff_stealthchop: 5
        toff_coolstep: 3
        use_enable: false
        step_pin: I2SO.10
        direction_pin: I2SO.9
        disable_pin: I2SO.8
     #B
   # motor1:
   #   limit_neg_pin: NO_PIN
   #   limit_pos_pin: gpio.34:high
   #   pulloff_mm: 4.000
   #   tmc_2209:
   #     uart_num: 1
   #     addr: 3
   #     cs_pin: i2so.19
   #     run_amps: 0.800
   #     hold_amps: 0.500
   #     microsteps: 8
   #     stallguard: 0
   #     toff_disable: 0
   #     toff_coolstep: 3
   #     use_enable: false
   #     step_pin: I2SO.18
   #     direction_pin: I2SO.17
   #     disable_pin: I2SO.16
#  c:
#    steps_per_mm: 80.000
#    max_rate_mm_per_min: 5000.000
#    acceleration_mm_per_sec2: 100.000
#    max_travel_mm: 300.000
#    soft_limits: false
#    homing:
#      cycle: 0
#      positive_direction: true
#      mpos_mm: 150.000
#      feed_mm_per_min: 100.000
#      seek_mm_per_min: 800.000
#      settle_ms: 500
#      seek_scaler: 1.100
#      feed_scaler: 1.100
#    motor0:
#      limit_neg_pin: gpio.39:low
#      pulloff_mm: 3.000
#      tmc_2209:
#        uart_num: 1
#        addr: 3
#        cs_pin: i2so.22
#        run_amps: .8
#        hold_amps: 0.050
#        microsteps: 16
#        stallguard: 0
#        toff_disable: 0
#        toff_coolstep: 3
#        use_enable: false
#        step_pin: I2SO.21
#        direction_pin: I2SO.20
#        disable_pin: I2SO.23
i2so:
  bck_pin: gpio.22
  data_pin: gpio.21
  ws_pin: gpio.17
spi:
  miso_pin: gpio.19
  mosi_pin: gpio.23
  sck_pin: gpio.18
sdcard:
  cs_pin: gpio.5
  card_detect_pin: NO_PIN
  frequency_hz: 20000000
probe:
  pin: gpio.36:low
  toolsetter_pin: NO_PIN
  check_mode_start: true
start:
  must_home: false
coolant:
  flood_pin: gpio.2
  mist_pin: gpio.16
  delay_ms: 0
control:
  safety_door_pin: NO_PIN
  reset_pin: NO_PIN
  feed_hold_pin: NO_PIN
  cycle_start_pin: NO_PIN
  macro0_pin: NO_PIN
  macro1_pin: NO_PIN
  macro2_pin: NO_PIN
  macro3_pin: NO_PIN
macros:
  startup_line0:
  startup_line1:
  macro0:
  macro1:
  macro2:
  macro3:
user_outputs:
  analog0_pin: NO_PIN
  analog1_pin: NO_PIN
  analog2_pin: NO_PIN
  analog3_pin: NO_PIN
  analog0_hz: 5000
  analog1_hz: 5000
  analog2_hz: 5000
  analog3_hz: 5000
  digital0_pin: gpio.26
  digital1_pin: gpio.27
  digital2_pin: NO_PIN
  digital3_pin: NO_PIN
#Laser:
#  pwm_hz: 5000
#  output_pin: gpio.27
#  enable_pin: NO_PIN
#  disable_with_s0: false
#  s0_with_disable: true
#  tool_num: 0
#  speed_map: 0=0.000% 255=100.000%
#  off_on_alarm: true
# pwm:
#  pwm_hz: 5000
#  direction_pin: gpio.26
#  spinup_ms: 0
#  spindown_ms: 0
#  tool_num: 0
#  speed_map: 0=0.000% 1000=100.000%
#  off_on_alarm: false
# 5V out gpio.26/27
# VMot out gpoi.2/16
# In's left to right gpoi.25/33/32/35/34/39/36
First, disconnect the endstops. The motors look right. But it looks like the endstops are connected to the top of the TMC. You should be able to run it without endstops to get started. You will need to reset the alarm to move at first.
If you got the config file from Ryan, then it is probably right.
What are you doing to test it, what do you expect and what do you observe?
The docs are missing a wiring picture for the ZenXY, but it looks like the config file is set up for the endstops to use these 3
