Jackpot power supply advice
Hi All!
These may be very stupid questions but what are the requirements for the power supply? I see on the shop Ryan sells a 24v 2.5A laptop style power supply, but is it the datasheet for the jackpot board shows input as 9-24VDC.
So my questions are
  1. Does that mean I can use a power supply I have around (12v - 10A) or do I need a 24v supply?
  2. Would a too large supply be a problem, I found a good deal locally (South Africa) on a 24V - 10A (250W) supply? Would that just blow my board up? :woman_shrugging::joy:
  3. Outside of possible, which would be preferred? I imagine one like being sold on the store.
I bought a jackpot board from the v1 shop and had a friend bring it to me in South Africa since shipping is a nightmare, just don’t want to see the dreaded blue smoke :joy:
Thanks in advance
Welcome to the V1 family Keelan. I am using a 24V - 30A power supply with no problems. You should be fine with the 10A.
Ah thank you Britt! Both for the welcome and the advice :blush: I’ll most likely pick that 10A one up then.
I have just finished all the mechanical assembly, so moving onto way less comfortable territory but its been such a fun build thus far!
Hello and welcome :smile: I have V1E map project (it is work in procress.) I would be so happy if you could add your machine into the map after the machine is ready (and map :see_no_evil:) ATM no mapped machines at Africa.
Ah thats super cool! and yeah I’d be proud to be the first MPCNC on your map from my continent :blush: I’ll definitely add it once its up and running
The board will only draw what it draws, the rating on the ps is how much it’s capable of supporting. A 1000hp engine goes pretty slow when it’s at idle.
