Jackpot / FluidNC WebGUI
Here’s a proof of concept that can be done via a theme and uploading an image. It seems like if you hang out here long enough, you’re going to end up with a collection of Jackpots. It would be nice if you could quickly see which machine you are connected to.
This is similar to work in the software world where the UI looks a bit different to distinguish between dev/test/prod environments.
Or it’s fun to just have a fancy logo. So, I took a V1E logo, plus an LR3 logo from @DougJoseph and made an image which I uploaded to the Jackpot. I’m am certainly not a graphic artist.
LowRider v3 Nameplate / Logo-Text, 8 Variations - LowRider CNC / Hardware Development - V1 Engineering Forum
You give that logo a generic name like logo.png. Then update the theme to use that logo. So, you can use the same theme on each machine but upload a different image.
Flash space is at a premium so you can’t get too carried away. I also got it to work using the SD card but I’m curious if there is a downside to that.
It could have a mobile version of the image too that takes up less space. So, when the width gets too small, this could just be the small V1 logo with LR3.
Thoughts?
