Jackpot controller Prob showing activated even when wire is disconnected from the board
Hi All,
Getting the following message when trying to Prob
ALARM:4 Probe fail. Probe is not in the expected initial state before starting probe cycle.
I see that the light is activated even after I disconnected the wire from the controller, any advice please.
FluidNC v3.9.1
Some questions:
did it ever work?
Can you show us your $SS output from the terminal?
If you use $Limits to test the probe and end stop behavior, does everything toggle correctly when you tap the endstop or probe? If not, which things work and don’t work?
Hi,
Yes it was working fine TBH I don’t use it usually as it’s not very accurate when cutting mostly I use to calibrate the z axis.
Running $ss
Commands
$SS
[MSG:INFO: FluidNC v3.9.1 GitHub - bdring/FluidNC: The next generation of motion control firmware]
[MSG:INFO: Machine LowRider]
[MSG:INFO: Axis count 3]
[MSG:INFO: Axis X (3.000,1263.000)]
[MSG:INFO: Motor0]
[MSG:INFO: Axis Y (3.000,2483.000)]
[MSG:INFO: Motor0]
[MSG:INFO: Motor1]
[MSG:INFO: Motor0]
[MSG:INFO: Z Pos Limit gpio.32]
[MSG:INFO: Motor1]
[MSG:INFO: Z2 Pos Limit gpio.34]
[MSG:INFO: AP started]
[MSG:INFO: WiFi on]
[MSG:INFO: Probe gpio.36:low]
ok
Running
$ limitis not doing anything when activating the switches just showing P
Ok, you need to troubleshoot and fix you limit switches and possibly probe depending on how you defined the probe
