So after a long night of going down a pretty deep rabbit hole, I am sort of lost and cannot figure out what is going on. I finished building my CNC and plugged in the Jackpot board and all the stepper motor wires (no endstops yet, still waiting on longer wires). I connected via wifi and tried to move the motors using the arrows but nothing worked. After reading some stuff on FluidNC wiki, I plugged the ESP into my laptop, load up the FluidNC Web Installer. I did a fresh install, downloaded the V3 config file and uploaded it under the file manager within the web application. I then restart the controller and try to connect via wifiâŚno luck.
Next I followed the wifi steps on the FluidNC wiki. Tried to configure Wifi as stated but also no luck.
Was the controller suppose to work straight out of the box when I connected to WiFi? I spent a few hours and can still not figure it out. Any help would be appreciated.
Did you fill out the SSID and password for your home network? If you did, then youâll need to find it by IP on your home network as in STA mode it wonât show up as an AP named FluidNC any longer.
Depending on your home network setup, you might be able to find your machine by pointing at fluidnc.local. If that fails, you will need to figure out how to see the connected devices to your home AP or router and then use that to point to the IP address of your web interfaxe.
Solved!
Honestly I was just about to call it a night, but I figured what the hell, might as well try a full reboot again. This time I did a fresh install, uploaded the config file, but I did NOT touch the WiFi settings. I just let it be and it worked that time. The only problem with this is that I would have to disconnect from my home wifi to access the WebUI instead of just connecting to it while still connected to my home Wifi is that correct?
I will revisit this issue tomorrow, but what a good way to wrap up the night.
If you want to be on your home internet you can use STA mode but you will need to use fluidnc.local or find the IP on your network. We ship in AP mode so it is easy to find.
Yes, every single board is tested on wifi before it leaves.
Iâve since gotten it up and running and drawing pictures. Occasionally it disconnects or lags a little when drawing the pictures. I got this error tonight, anyone know what its for? It will not let me go past this screen.
I turned it off and went back downstairs to connect again and seems to be working perfectly fine now. Maybe its the beta version causing some various issues. I will upload 3.8.0 tomorrow after work and try it out.
So opening this thread back up. I have been having some issues with FluidNC and the web app. I have done a full wipe and re-configured. Motors worked to home just fine. Unplugged the motors to do some wire management, plugged back in and no connection. Canât manually jog the axis back and forth. I did another full wipe thinking it was something wrong with that. Tried homing and motors were very jittery (I am guessing its something with software because motors were running fine just minutes before, so not a physical issue with the trucks). Tried connecting again and got an error below, config file is already uploaded but its saying its invalid. Went in to the installer and re-uploaded the config file, re-connected and it wont stay connected to the Jackpot (wifi keeps dropping out after the webapp is opened up. Also got this message when I re-connected to try it again:
ERROR:8 Grbl â$â command cannot be used unless Grbl is IDLE. Ensures smooth operation during a job. Error : undefined :undefined [MSG:ERR: Command requires idle state] [MSG:INFO: Caution: Unlocked] ok
Anything I can try? Do I have a bad ESP? I will note the wifi kept dropping out when I first tried it out. Has been a recurring issue.
ERROR:152 Configuration is invalid. Check boot messages for ERRâs. Error : undefined :undefined [MSG:ERR: Configuration is invalid. Check boot messages for ERRâs.]
Did you modify your config.yaml? That error means there is something wrong in the config. You did upload it back to the ESP after re-flashing correct?
As far as your motors jittering, I would check your wiring. Make sure all the wires are fully seated in all the motor dupont connectors. If one is pulled out just a little it can be making a bad connection. Also check any extension cables where they plug in. If you wire managed too tight it could have pulled something just barely loose where its not making a good connection
Went for a break actually and figured I might as well try re-uploading it again and in the FluidNC Web Installer it says âThe controller does not seem to have FluidNC installed, do you wish to install it?â, which is weird because I did install it and re-uploaded the V3 config file from GitHub. Going to try re-flashing and uploading config again and see what happens.
Motors seem back to normal for a short amount of time I was able to run the machine before it disconnected again. I did unplug a powered stepperâŚmy bad.
Everything seems to be working normally now, had an issue with a Z-stepper motor not connecting, but tried it multiple times and it works now. What do you use instead of the web installer?
So everything has been working fine but today and yesterday specifically keep giving me startup alarms as seen below from message panel. I tethered up to the board and made sure everything was installed. Everything looks good. Not sure what is wrong. Keeps giving me a âConfig File Error Fix it or FluidNC will not workâ but the config file looks good
$G
[GC:G0 G54 G17 G21 G90 G94 M5 M9 T0 F0 S0]
ok
$SS
<Alarm|MPos:0.000,0.000,0.000|FS:0,0|WCO:39.188,29.188,10.000>
[MSG:ERR: Showing startup log from previous panic]
[MSG:INFO: FluidNC v3.8.0 GitHub - bdring/FluidNC: The next generation of motion control firmware]
[MSG:INFO: Machine MPCNC]
[MSG:INFO: Stepping:I2S_static Pulse:4us Dsbl Delay:0us Dir Delay:1us Idle Delay:255ms]
[MSG:INFO: User Digital Output:0 on Pin:gpio.26]
[MSG:INFO: User Digital Output:1 on Pin:gpio.27]
[MSG:INFO: Axis count 3]
[MSG:INFO: Axis X (0.000,1220.000)]
[MSG:INFO: Motor0]
[MSG:INFO: Motor1]
[MSG:INFO: X2 Neg Limit gpio.35]
[MSG:INFO: Axis Y (0.000,2440.000)]
[MSG:INFO: Motor0]
[MSG:INFO: Motor1]
[MSG:INFO: Y2 Neg Limit gpio.34]
[MSG:INFO: Axis Z (-100.000,200.000)]
[MSG:INFO: Motor0]
[MSG:INFO: Z Neg Limit gpio.32:low]
[MSG:INFO: X2 Axis driver test passed]
[MSG:INFO: Using spindle NoSpindle]
[MSG:INFO: Probe gpio.36:low]
[MSG:INFO: AP started]
[MSG:INFO: WiFi on]
ok
Try pulling out your drivers and carefully putting them back in. Insert them straight in, not front to back or side to side, push them straight in. Maybe one of the pins is making funky contact.
