Jackpot config
Here is my config for my ZenXY table. I have not tested it yet. Posting it here for people smarter then me to look at and see if I need to change anything. My jackpot board is V1.2 10/2023 ESP32-wroom-32d espressif.
board: Jackpot TMC2209
meta: 05-28-2024 BradH
stepping:
  engine: I2S_static
  idle_ms: 255
  pulse_us: 4
  dir_delay_us: 1
  disable_delay_us: 0
  segments: 12
uart1:
  txd_pin: gpio.0
  rxd_pin: gpio.4
  rts_pin: NO_PIN
  cts_pin: NO_PIN
  baud: 115200
  mode: 8N1
i2so:
  bck_pin: gpio.22
  data_pin: gpio.21
  ws_pin: gpio.17
spi:
  miso_pin: gpio.19
  mosi_pin: gpio.23
  sck_pin: gpio.18
sdcard:
  cs_pin: gpio.5
  card_detect_pin: NO_PIN
  frequency_hz: 20000000
kinematics:
  Corexy:
axes:
  shared_stepper_disable_pin: NO_PIN
  shared_stepper_reset_pin: NO_PIN
  x:
    steps_per_mm: 50.000000
    max_rate_mm_per_min: 9000.000000
    acceleration_mm_per_sec2: 200.000000
    max_travel_mm: 1220.000000
    soft_limits: false
    homing:
      cycle: 2
      allow_single_axis: true
      positive_direction: false
      mpos_mm: 0.000000
      feed_mm_per_min: 300.000000
      seek_mm_per_min: 1500.000000
      settle_ms: 500
      seek_scaler: 1.100000
      feed_scaler: 1.100000
    motor0:
      limit_neg_pin: gpio.25
      limit_pos_pin: NO_PIN
      limit_all_pin: NO_PIN
      hard_limits: false
      pulloff_mm: 5.000000
      tmc_2209:
        addr: 0
        cs_pin: NO_PIN
        uart_num: 1
        step_pin: I2SO.2
        direction_pin: I2SO.1
        disable_pin: I2SO.0
        r_sense_ohms: 0.110000
        run_amps: 0.680000
        hold_amps: 0.500000
        microsteps: 8
        toff_disable: 0
        toff_stealthchop: 5
        use_enable: false
        run_mode: StealthChop
        homing_mode: StealthChop
        stallguard: 0
        stallguard_debug: false
        toff_coolstep: 3
  y:
    max_travel_mm: 2440.000000
    soft_limits: false
    homing:
      cycle: 2
      mpos_mm: 0.000000
      settle_ms: 500
    motor0:
      limit_neg_pin: gpio.33
      hard_limits: false
      tmc_2209:
        addr: 1
        cs_pin: NO_PIN
        uart_num: 1
        step_pin: I2SO.5
        direction_pin: I2SO.4
        disable_pin: I2SO.7
        run_amps: 0.680000
        hold_amps: 0.500000
        microsteps: 8
        toff_disable: 0
        toff_stealthchop: 5
        use_enable: false
        stallguard: 0
Something went wrong with your code post, and formatted that way we can’t look at the indenting.
Can you re-post it in the blockquote style. The whole thing should look like this:
stepping:
engine: I2S_static
idle_ms: 255
pulse_us: 4
dir_delay_us: 1
disable_delay_us: 0
segments: 12
stepping:
  engine: I2S_static
  idle_ms: 255
  pulse_us: 4
  dir_delay_us: 1
  disable_delay_us: 0
  segments: 12
uart1:
  txd_pin: gpio.0
  rxd_pin: gpio.4
  rts_pin: NO_PIN
  cts_pin: NO_PIN
  baud: 115200
  mode: 8N1
i2so:
  bck_pin: gpio.22
  data_pin: gpio.21
  ws_pin: gpio.17
spi:
  miso_pin: gpio.19
  mosi_pin: gpio.23
  sck_pin: gpio.18
sdcard:
  cs_pin: gpio.5
kinematics:
  Corexy:
axes:
  x:
    soft_limits: false
    homing:
      cycle: 2
      mpos_mm: 0.000000
      settle_ms: 500
   motor0:
      hard_limits: false
      tmc_2209:
        addr: 0
        cs_pin: NO_PIN
        uart_num: 1
        step_pin: I2SO.2
        disable_pin: I2SO.0
        run_amps: 0.680000
        hold_amps: 0.500000
        microsteps: 8
        toff_disable: 0
        toff_stealthchop: 5
        use_enable: false
        stallguard: 0
        toff_coolstep: 3
  y:
    soft_limits: false
    homing:
      cycle: 2
      mpos_mm: 0.000000
      settle_ms: 500
   motor0:
      hard_limits: false
      tmc_2209:
        addr: 1
        cs_pin: NO_PIN
        uart_num: 1
        step_pin: I2SO.5
        disable_pin: I2SO.7
        run_amps: 0.680000
        hold_amps: 0.500000
        microsteps: 8
        toff_disable: 0
        toff_stealthchop: 5
        use_enable: false
        stallguard: 0
Block quote isn’t right for code. The preformatted text is better. You start and end the preformatted text with three backticks on their own line:
Code
Code
Code
I’ve edited both posts.
Now let me go take a look…
Those should be 100.
I don’t see the corexy bit. I think it should be this:
kinematics:
    corexy:
And blank line after that.
I don’t have the jackpot pins memorized, but I assume you took this from another working jackpot file.
There is a bit of startup homing I figured out for my RMRRF table. We should add that to the default too, for the optical endstops and homing order.
Thanks I have changed it. My order is going to be here on Friday but I wont be home so I will have to wait until Sunday to see if I will get this working. I will let you all know if this works.
