Hello, I have a LR3 with a MKS GEN L 2.1 board and TMC2209 drivers that was working fine. The PSU is 24v and it is powered on. However, now, one of them is outputing an error: All LOW TMC CONNECTION ERROR. This issue is on the Z axis and only Z2 displays this error. The strange thing is that the motor is working, but is really out of sync with the Z1.
I already have swapped the motors and drivers and the problem still persists in the Z2. The output for the M122 command was:
Testing X connection... OK
Testing Y connection... OK
Testing Y2 connection... OK
Testing Z connection... OK
Testing Z2 connection... Error: All LOW
//action:notification TMC CONNECTION ERROR
>>> m122
SENDING:M122
X Y Y2 Z Z2
Address 0 0 0 0 0
Enabled false false false false false
Set current 900 900 900 900 900
RMS current 887 887 887 887 1602
MAX current 1251 1251 1251 1251 2259
Run current 28/31 28/31 28/31 28/31 28/31
Hold current 14/31 14/31 14/31 14/31 14/31
CS actual 14/31 14/31 14/31 14/31 0/31
PWM scale
vsense 1=.18 1=.18 1=.18 1=.18 0=.325
stealthChop false false false false false
msteps 32 32 32 32 256
interp true true true true false
tstep max max max max 0
PWM thresh.
[mm/s]
OT prewarn false false false false false
pwm scale sum 16 16 16 16 0
pwm scale auto 0 0 0 0 0
pwm offset auto 36 36 36 36 0
pwm grad auto 14 14 14 14 0
off time 3 3 3 3 0
blank time 24 24 24 24 16
hysteresis
-end -1 -1 -1 -1 -3
-start 1 1 1 1 1
Stallguard thrs 0 0 0 0 0
uStep count 4 996 4 4 0
DRVSTATUS X Y Y2 Z Z2
sg_result 0 0 0 0 0
stst *
olb * * * *
ola * * * *
s2gb
s2ga
otpw
ot
157C
150C
143C
120C
s2vsa
s2vsb
Driver registers:
X 0x80:0E:00:C0
Y 0x80:0E:00:C0
Y2 0x80:0E:00:C0
Z 0x80:0E:00:C0
Z2 0x00:00:00:00 Bad response!
Does anyone has any ideas about what might be causing this? Thank you in advance.
