Internal pocket EstlCAM program help
How do I program this cut. I want the cut to start 0.25 inches down, and also leave the lip for a capture.
Window on top I am just using the peel, hole, but I would like a pocket (or second hold) 0.25in under this hole, but to not cut out the top of it.
This was just a super rough sketch of what I am trying to do.
The 2D drawing would be two squares. Cut the smaller as a full depth pocket. The bigger square could be cut as a hole with a T-slot cutting bit. It would need a Start Depth that is the thickness of the lip plus the height of the perimeter cutting edge. Set a Lead-in point near the center of the pocket so the bit will drop to the start depth where there is no longer any material.
This seems like it will work, but the problem is that it wants to come up to “safe 0” to move to the next side, instead of going back to the lead-in spot.
Screenshot? All Z moves happen at the lead-in spot (second mouse click) and the only time the bit goes back to the clearance plane is when it’s done cutting the hole.
Can’t post enough pics, and can’t upload attachments.
here is the best I can do, the circles are the illegal moves.
The second cut (T-slot) should be a hole (not pocket), all it needs to cut is what the first cut (straight bit pocket) cannot… That second cut will be full depth sideways. If that is too much, add an intermediate square to cut the undercut in two steps.
ok, got it, so 2 step (square) process to keep the heat off, so to speak.
It really depends on the machine and T-slot bit, a standard 1/2" T-slot undercut is ~3/16" tall x 1/8" deep sideways.
I’m using a 3/4 inch bit lol I’ll give it a go. Trying to do some black walnut
Can you rotate the piece so the open end is up? Then you could make the whole cut with one operation.
