I wanted to share how I setup Estlcam on my Mac with Apple silicon (arm).
Problem there was, that installing wine using homebrew does not work anymore, as the wine packages are considered “unsigned” by Apple and brew has removed the --no-quarantine flag, which was needed to pass that check.
Note that the way Estlcam is installed below does not support controlling the MPCNC (running Estlcam12_CNC.exe).
Instead I installed wine directly, removed the quarantine flag by hand and then I could install Estlcam:
softwareupdate --install-rosetta --agree-to-license # Wine needs Rosetta on Apple Silicon
cd ~/Downloads
curl -LO https://github.com/Gcenx/macOS_Wine_builds/releases/download/11.18/wine-staging-11.18-osx64.tar.xz
tar xf wine-staging-11.18-osx64.tar.xz
mv "Wine Staging.app" /Applications/
xattr -dr com.apple.quarantine "/Applications/Wine Staging.app"
After this you can run “Wine Staging”. Accept that it opens up a terminal. In the newly created terminal then execute the Estlcam install and run Estlcam::
wine ~/Downloads/Estlcam_64_12155.exe
wine "C:/Program Files (x86)/Estlcam12/Estlcam12_CAM.exe"
Note that in future OS major versions you’ll need to install an x86 virtual machine as Apple has deprecated Rosetta and it will not be supported from MacOS 28 on.
