Initial Squaring
I have completed the building of the lr4.
I have determined that I have a difference of 3mm between my diagonals.
How do I add to the Y axis pull-off distance to correct any skew.
Is this setting in the configuration tab?
Welcome to the club! I’ll have to let someone else help you with setting pull off as I have not looked into that yet.
What control board do you have?
The instructions for inputting the offset for both boards are in the instructions
https://docs.v1e.com/lowrider/#initial-squaring
On a jackpot the setting is
axes/y/motor/pulloff_mm for the min side
axes/y/motor1/pulloff_mm for the max side
Remember to save using the macro button or it won’t be retained after a reboot.
