Illustrator text not being imported
I decided to start over doing the crown tutorial. I followed the instructions on setting it up in Estlcam. I resized it x 100.
I saved it as Crown_2.Gcode. Then I loaded it in Repetier-Host but the image doesn’t appear even though the code is there.
Did you try the pre-made test crown first (from the zip file on link)?
That one has been tested on probably the majority of the machines built. It will rule out any CAM issues from your end and verify that your setup is running properly.
If I remember correctly, Repetier Host won’t give you a preview if you just load a Gcode file. The preview is only for loading STLs and slicing. But then again, I haven’t used it in a while, and never for CNC :sweat_smile:
@Jerrymc3 FYI, here are a couple online viewers that I use to give me a little more confidence in my CAM program.
https://nraynaud.github.io/webgcode/
