Does anyone know where can I buy them, or where can I get the template to cut them myself,??
Pretty much that is all I am missing now. & Does anyone have cut MDF with the LOWRIDE that can tell me about their experience, since that is the material Ill be cutting
I am not sure, if am wrong or I am confused, but the drawing I found its like this, and the plate that I see is sold out (which looks like the ones that the others have, or were selling) the point is, is not similar, I am confused there
If your the kind of guy that likes to print out 1:1 templates and then use spray adhesive to fix them to your board for easy cutting, and have marks for center punching your holes, then this might be for you. My local print shop will print something like this out for a few bucks.
good evening
When do you think the LOWRIDER2 25.4MM OD FLAT PARTS will be available for sale.
Can you advise me another place to order it.
Reminding you
I do not have a restocking time at this point. The DXF’s are available for you to print and use as templates if you want them now. You can then use your CNC to cut a nice set or two.
Hello,
I do not have a Cnc, my object is to assemble one.
Exactly for I do not flat, I'm looking for a way to get me.
Since there is a break on your site.
Do you think all parts are 25 mm compatible
thank you
My only suggestion at this point is to make them by hand by printing out a template from the DXF’s. If they come out great you are done if not they should easily be good enough to use and cut a new set with the CNC.
I have other questions:
Can you give me the maximum tube lengths you need in X and Y
Diameter of the tube in mm
Concerning the side rails, the link to amazon no longer works.
Thickness of the medium, so that I make it realize
Thanking you
The tube (not pipe) diameter is in the name of the parts, either 25mm or 25.4mm. There is also a size calculator on that page to compute the tube length for a specific machine size.
This project is not an ikea bookcase, and you’ll have to do some learning to get to the finish. This is between a DIY and a complete setup. Things like DXF files and following the instructions (and filling in the gaps) are going to be skills you need. There are lots of people performing volunteer support here, but evem if we help you build the whole machine, you’ll have to run it.
I agree with you, but it is difficult to machine parts without having a file with the dimensions (DXF file).
I understood that it was necessary to search.
The questions I ask on the forum also serve me to understand
grember, the DXF file is linked on the parts page, on the thingiverse page, and a few posts up in this thread. I am not sure if we are not understanding each other or not, but the file you are asking for is linked everywhere.
Would it be ok if I asked you to share a pdf version that I can print out for the CNC flat parts? I read the FAQ and downloaded eDrawings and at this point have probably wasted about 50 sheets of paper now trying to get the program to print 1 to 1 like its supposed to but for whatever reason it’s printing too small regardless of making sure its set to 1 to 1 and printer options are set to correct scale.
