How to wire limit switches?
I have bought the limit switches from our local store and it has 3 pins (VCC-GND-OUT), where should i plug them into on jackpot 3? I don’t see any 3 pin inputs on the jackpot3.
You should only need 2 wires. They are basically an off/on switch.
  • VCC (COM) – Common terminal; this is the input side of the switch.
  • GND – One of the output contacts (often NO or NC).
  • OUT – The other output contact (the opposite of GND).
Example for Normally Open (NO) mode:
  • VCC (COM) and GND (NO).
  • OUT (NC) → not connected in this mode.
So, you should only need to worry about the VCC and GND connections.
