How to power two 40mm fans on skr pro v1.2 board?
If your fan plugs are 2-pin or can be modified to be 2-pin, there appears to be two 12V pins in the lower right of the SKR Pro 1.2 board in this diagram.
Using these would mean you would not have to add g-code to turn the fans on for a job. They would be on anytime the board is powered.
