Hello Everyone!
I’m into my build of the MPCNC… the US 1" SS version. Most of the parts are printed and am starting to get into some assembly.
I grabbed some 5/16" bolts and was doing some measuring.
The bearings have an ID measurement of .316" (approx.)
A standard “off the shelf” US 5/16" bolt has an OD of .306" (approx.)
The question now is, does the design have tolerances built in to account for this much play?
Should I consider other options to remove the “slop” between bolt and bearing?
Options (maybe?):
- Just roll with it as is?
- Source some metric (8mm) bolts and nuts (what does an 8mm bolt actually measure on the OD)?
- get some steel and mill my own parts on the lathe (YAY! more work… ugh!)?
What do guys think?
Thanks for your advice,
Trevor
