How does the FoxAlien Masuter Pro compare?
@Heatsink Glad you made a choice as to what you were going to do and good luck with your build.
I waned to add for those other newbies that come across this post in their research for CNC machines:
This still rings true with a prebuilt system you get right out of the box. Most CNCs still have “some assembly required” and will still need to be tuned and calibrated. YES, the assembly part is much easier as it is just “insert Tab A into Slot B and use machine screw from package 1,” and it will still just “work” out of the box, but for it to be worth anything, you will still need to calibrate and tune it. Just like any 3D printer.
Just my $.02!
