How Calibration fluidnc
Hi
please help me to how Calibration fluidnc
Hi,
If you are using a MPCNC or LowRider kit from here, there is no calibration needed.
If you are using anything else, we need all the details of your use and your components.
By calibration, do you mean squaring and Z leveling? If so, it involves setting the “pulloff_mm” settings for the endstops.
https://docs.v1e.com/electronics/jackpot/#auto-square
Thank you all for helping me
But what I mean is when I drill a circle with a diameter of 10 mm, he drills it with a diameter of 20 mm.
In the grbl settings, you change them in
$100 = 41.292 (X-axis travel resolution, step/mm)
$101 = 41.292 (Y-axis travel resolution, step/mm)
$102 = 52,000 (Z-axis travel resolution, step/mm)
As for Fluidnc, I am new to using it, so I have some difficulty using it, so I asked for help with that
my regards
The Yaml files we provide work for our kits and the components they come with, if you bought others you need to edit the steps per mm in the yaml file.
