I’ve tried several times to set up STA. I’ve inserted my WiFi SSID, and my password. When I click save, I get the endless spinning. I have very fast WiFi and have several 3d printers running on static IPs. Any help would be appreciated.
Where are you entering it? WebUI? Web installer? Screenshots are helpful.
Do you have 2.4Ghz WiFi? ESP-32s we use don’t have 5GHz or 6Ghz radios.
WebUI
EERO mesh that handles either.
A screenshot would still help. There’s WebUI v2 and v3 plus the latest version of v3 has a settings tab for configuring this.
If you were using this while connected to the AP, that would mean you need to switch whatever you are accessing the WebUI on to that network.
You should also have it in the mode where if it can’t connect in STA mode, it falls back to AP mode.
I have had to reboot mine to get it all to connect once. From there setting up a static IP is highly recommended, and pretty easy from the app.
I tried doing everything I had before from my iPad sitting in my living room. It worked perfectly. Guess I was too close to the Jackpot 3 or it didn’t like the Chromebook.
