X is working fine y and z max out travel and continue to run I’ve rewired and checked connections to many times to count manual control works as should I’m stumped
Travel will not stop when endstop is toggled (doesn’t stop on x travel either) they are brand new please help me figure this out thanks
Travel does not stop the CNC, the endstops are only active when homing.
If Y and Z continue you might have mixed up one Y and one Z cable. So for instance Y1 is triggering but not Y2 because Y2 is on your Z motor. Try to press the endstops manually one by one without homing and check the lights on the Jackpot and whether the light you think should toggle actually does toggle.
Thank Philipp I have them backwards all 3 home properly thanks for your help
That’s great to hear, happy to help. I did the same thing on my Primo after converting it to have endstops after having used V1 CNCs for three years and wondered what the hell my problem was. It happens to all of us… ![]()
Mark it as a solution, please. ![]()
