I can not get a fully threaded screw of 5 / 16-18 X 5.
I get it with a screw on the tip, or fully threaded 4 inches. The same with the m8x130.
Some alternative? Threaded rod with a nut on each point ?.
I also do not get the 6-32 nuts with Nylock. Can I use grower and loctite?
Thanks.
vicious1
(Ryan)
June 14, 2018, 11:48am
2
It does not need to be fully threaded. Loctite is fine.
Should be, you can see what we use here, in the second image.
Parts bundle for Mostly Printed CNC
This works with all 3 versions (23.5mm, 25mm, 25.4mm).
*You will still need printed parts, conduit, and a spindle.* *optional but recommended is an LCD as well for headless use*
Options; The control...
Price: USD 207.00
ottobot
(Otto)
June 24, 2018, 7:09pm
5
Are there any disadvantages of using fully threaded parts? I sent my local dealer fastenal a screenshot of the parts list and they gave me almost everything fully threaded.
