Hi Follow up to this Please.
I have MPCNC with enstops on all axis.
movements are going the right way endstops are triggering.
only issue i have is the Y axis only one moves when homing, but when i jog both move.
$0 = 10 (Step pulse time, microseconds)
$1 = 255 (Step idle delay, milliseconds)
$2 = 0 (Step pulse invert, mask)
$3 = 24 (Step direction invert, mask)
$4 = 0 (Invert step enable pin, boolean)
$5 = 0 (Invert limit pins, boolean)
$6 = 0 (Invert probe pin, boolean)
$10 = 1 (Status report options, mask)
$11 = 0.020 (Junction deviation, millimeters)
$12 = 0.002 (Arc tolerance, millimeters)
$13 = 0 (Report in inches, boolean)
$20 = 0 (Soft limits enable, boolean)
$21 = 1 (Hard limits enable, boolean)
$22 = 1 (Homing cycle enable, boolean)
$23 = 31 (Homing direction invert, mask)
$24 = 200.000 (Homing locate feed rate, mm/min)
$25 = 2000.000 (Homing search seek rate, mm/min)
$26 = 200 (Homing switch debounce delay, milliseconds)
$27 = 2.000 (Homing switch pull-off distance, millimeters)
$30 = 1000 (Maximum spindle speed, RPM)
$31 = 0 (Minimum spindle speed, RPM)
$32 = 0 (Laser-mode enable, boolean)
$100 = 200.000 (X-axis travel resolution, step/mm)
$101 = 200.000 (Y-axis travel resolution, step/mm)
$102 = 3200.000 (Z-axis travel resolution, step/mm)
$103 = 200.000
$104 = 200.000
$110 = 4500.000 (X-axis maximum rate, mm/min)
$111 = 4500.000 (Y-axis maximum rate, mm/min)
$112 = 300.000 (Z-axis maximum rate, mm/min)
$113 = 4500.000
$114 = 4500.000
$120 = 200.000 (X-axis acceleration, mm/sec^2)
$121 = 200.000 (Y-axis acceleration, mm/sec^2)
$122 = 200.000 (Z-axis acceleration, mm/sec^2)
$123 = 200.000
$124 = 200.000
$130 = 642.000 (X-axis maximum travel, millimeters)
$131 = 642.000 (Y-axis maximum travel, millimeters)
$132 = 120.000 (Z-axis maximum travel, millimeters)
$133 = 642.000
$134 = 642.000
Help will be appreciated.
