Hello everyone, I thought I would share my build and try to attach some pics as well as the configs for my GRBL.
Before I get Started just to let everyone know I never touched a CNC till I started building this one so be gentle.
First Off I went with a 24 x 24 x 4, build platform, Im running Open Builds Black Box with GRBL,
(I got it on sale didn’t pay what its listed for now), I liked it as well as their other stuff due to how modular everything is and once configured its plug and play. I also use their power supply https://openbuildspartstore.com/24v-meanwell-power-supply-bundle/
and power relayhttps://openbuildspartstore.com/iot-switching-relay-power-strip/ which you can cheaper in other places, its really nice for power on my my DW 660 and my vac when I get it hooked up from the the console. I use a combo of V-carve desktop and fusion 360 ( very much a noob at both, Vcarve is very intuitive and easy to learn) for design and post processing, I use Open builds Open Control https://openbuildspartstore.com/openbuilds-control/
for machine control, agan very intuitive, and for me easy to learn and get around in especially when making changes to GRBL. All of my parts I printed was on a Creality Ender 3 Pro, highly recommend, never skipped a beat and it ran constant for a good week printing everything. Other stuff was bought either from Ryan or the local hard ware store.
I will Try to post my set up file GRBL:
$0=10 ;Step pulse time, microseconds
[14:51:00] [ $$ ] $1=255 ;Step idle delay, milliseconds
[14:51:00] [ $$ ] $2=0 ;Step pulse invert, mask
[14:51:00] [ $$ ] $3=101 ;Step direction invert, mask
[14:51:00] [ $$ ] $4=1 ;Invert step enable pin, boolean
[14:51:00] [ $$ ] $5=0 ;Invert limit pins, boolean
[14:51:00] [ $$ ] $6=0 ;Invert probe pin, boolean
[14:51:00] [ $$ ] $10=1 ;Status report options, mask
[14:51:00] [ $$ ] $11=0.020 ;Junction deviation, millimeters
[14:51:00] [ $$ ] $12=0.002 ;Arc tolerance, millimeters
[14:51:00] [ $$ ] $13=0 ;Report in inches, boolean
[14:51:00] [ $$ ] $20=0 ;Soft limits enable, boolean
[14:51:00] [ $$ ] $21=0 ;Hard limits enable, boolean
[14:51:00] [ $$ ] $22=1 ;Homing cycle enable, boolean
[14:51:00] [ $$ ] $23=0 ;Homing direction invert, mask
[14:51:00] [ $$ ] $24=100.000 ;Homing locate feed rate, mm/min
[14:51:00] [ $$ ] $25=1500.000 ;Homing search seek rate, mm/min
[14:51:00] [ $$ ] $26=250 ;Homing switch debounce delay, milliseconds
[14:51:00] [ $$ ] $27=5.000 ;Homing switch pull-off distance, millimeters
[14:51:00] [ $$ ] $30=1000 ;Maximum spindle speed, RPM
[14:51:00] [ $$ ] $31=1000 ;Minimum spindle speed, RPM
[14:51:00] [ $$ ] $32=0 ;Laser-mode enable, boolean
[14:51:00] [ $$ ] $100=50.000 ;X-axis steps per millimeter
[14:51:00] [ $$ ] $101=50.000 ;Y-axis steps per millimeter
[14:51:00] [ $$ ] $102=200.000 ;Z-axis steps per millimeter
[14:51:00] [ $$ ] $110=1000.000 ;X-axis maximum rate, mm/min
[14:51:00] [ $$ ] $111=1000.000 ;Y-axis maximum rate, mm/min
[14:51:00] [ $$ ] $112=1000.000 ;Z-axis maximum rate, mm/min
[14:51:00] [ $$ ] $120=100.000 ;X-axis acceleration, mm/sec^2
[14:51:00] [ $$ ] $121=100.000 ;Y-axis acceleration, mm/sec^2
[14:51:00] [ $$ ] $122=100.000 ;Z-axis acceleration, mm/sec^2
[14:51:00] [ $$ ] $130=508.000 ;X-axis maximum travel, millimeters
[14:51:00] [ $$ ] $131=508.000 ;Y-axis maximum travel, millimeters
[14:51:00] [ $$ ] $132=114.300 ;Z-axis maximum travel, millimeters
“I know their can be some tweaking to do, like I said very new to all this.”
And some pics, so If you have any questions or suggestions give me a shout.
