Have you found a lcd controller that you can use with your setup or do you run it directly from your mac?
I could never get clean cuts with my MPCNC GRBL build, so I upcycled the parts into a new machine already (too much flex in the guide rails from making it too large).
I had to have a laptop tethered via USB anyway to run Easel, so an LCD display on the machine wasnāt needed. That being said, I didnāt find an LCD smart controller for the GRBL shield I used and donāt think there are even pin outs on the shield for a display.
I seem to recall seeing some folks hacking a RAMPS smart controller display to work on a GRBL shield, but honestly canāt remember where I saw that now.
The latest version of grbl seems to support offline milling.
If you search on Amazon for āgrbl offlineā then youāll find a few options, the cheapest of which is:
https://www.amazon.ca/gp/product/B07Y1BPMXK
I ordered one of the above. It should show up in a month or two. Hopefully it comes with everything that is in the photos.
@fredwalter are you up and running with that offline display controller yet? Is it working OK?
@mcdanyel I am going to try to set up an arduino Uno with the CNC shield this weekend, to try to run Easel on it. Anything in particular I should pay attention to? You say that in Easel, Shapeoko 1 should be set in the machine type. Whatās the reason behind that? Doesnāt it run on x-carve or the āotherā option at all?
Iām going to answer my own question here, for future searches: Going MPCNC->Arduino Uno+CNC Shield->GRBL->Easel is pretty straight forward when hooking things up and get the machine running. But the steps per mm will be completely off and you will have to micro manage in the GRBL configuration according to https://github.com/gnea/grbl/wiki/Grbl-v1.1-Configuration, most importantly the $100-$102 (x,y,z) settings. Use Universal G-code sender for that. Many tutorial videos to search for. Even if Easel is very basic, youāll learn a few fundamental things in the process.
Did you ever get around to testing this?
Yep. That was years ago now. But it ran my mpcnc and I think my LR for a while. It introduced me to cncjs. It worked well.
does anyone know how to get spindle control using a grbl compiled firmware on a mks gen 1.4 board? I found the cpu.map file but i am not sure which pins to use to make it compatible with normal m3-m5 commands?
Just now finding this. Did anyone try Ugs UGS with this? I see ugs supports joystick, which is something i wanted for a while!
I am soooo sorry. I revived a very old thread!!!
I use UGS all the time but with a Uno and cnc shield no joystick though. I started with a ramps board but droped a end mill on it and shorted it out and had this on ha d and been using this for years now
Currently I am running: https://github.com/fra589/grbl-Mega-5XI
And using gsender.
I get a 404 page not found on that link
How do I set it up for the MPCNC?
Iām really struggling with the programming/firmware set up
Iāve tried uploading the firmware using Arduino IDE and VS Code, but canāt do it.
Iāve successfully used VS Code to upload Marlin to a Gen L 1.0 used in my 3D Printer but am struggling with GRBL (itās my first time)
