Good news and bad news
This is one reason that I will likely stick with my Primo, at least for now, rather than upgrade to an LR4, or build an LR4 from scratch. The increase in horizontal surface area would be like a black hole in my shop, destined to attract all the things. :smiley:
110% true
Oh I just call working on irrigation irritation as usually you are on your knees and digging through tree roots and things.
It’s a retro fit for free hot tub I am changing to a replaceable heater element style.
Does the slide-on still fit?
Hi Peter,
I had a tub and replaced it with a tray so that the slide on camper would fit. Sorry, for my poor grammar :disappointed:.
Are you on the Ubeaut Woodworking forum?
Cheers, Chris
Hi Chris, Do be careful of the load on that cantilever!
I’ve been rather inactive on the Woodwork forum for many years, but I pop in a lurk from time to time - @bitingmidge same avatar! I’ve been there since 2003 apparently, which it turns out is a very long time, but for the last few years I’ve mostly hung out here.
Is anything happening over there?
wow, I am missing something, I do not see a cantilever!
Sorry Chris, this is a proper hijack - the comment was made very much tongue in cheek.
@RockinRiley
The twin cab ute represents something like 30% of all new car sales in Oz, but many of them are loaded will beyond their designed capacity. There’s a bit of an ongoing epidemic of bent chassis due mostly to multiple forms of abuse. The majority are perfectly fine and the engineering is clearly fit for purpose, but to be fair, the advertising isn’t!
The following link is for information only but it’s a pretty fair description. I only mentioned it because I’d just got home from the beach, and saw a particularly fine example on my soujourn! :smiley:
can relate
One of my cnc tables says: hold my :beer:
LOL. My Primo is currently at or over capacity of stuff, but at least this time it’s because I’m actively migrating to the Jackpot board.
Last (I hope) parts arrive today, so I’m hoping to get out wrapped up in the next week. Then it’ll stay clear for projects, I promise. :stuck_out_tongue_closed_eyes:
Yes, im moving my shop actually have only one cnc in this old shop working, the others are waiting for the installment re/squaring, im also building 2 more (lr4) and hopefully will replace the lr2 and 3 with 2 more lr4 (unless there’s a new update down the track)
i am so happy with mine, unless it does something radically different, it is staying a lr4
:slight_smile:
That’s a lot of LowRiders… :grin:
Yep, and all of them still cheaper than my 4x8 workbee with rack&pinion :sweat_smile::joy: and they do the same work the only benefit is the wb has a floating z axis plate (paired with a spindle fixed height plate) that makes me 100% certain that my acm v-route gets the same deepness each and every time (0.5mm is the difference between a working piece and garbage)
How often are you replacing your V bits with that workflow?
i use 1440mm/min feedrates each vbit lasts for around 40/50 sheets actually, they get replaced with life still on them, ( i mostly keep using them with my palm routers for a couple of months
