I just startet my building process ordering the parts and i cant find the needed wheel spacers anywhere here in germany. Does someone know an alternative in europe?
And i am searching for a good watercooled spindle that isn’t to heavy and does a good job with the lowrider. Any tips in this matter?
I am also trying to star a LR build and it sounds like I am at a similar stage as you and have asked the same question.
I’d found a couple of air cooled 1.5KW and water cooled 2.2KW spindles with VFD drives on eBay (ironically enough from German) for similar money to the recommended Dewault . Now 3 things have finally persuaded me to go for the international version of the 230Vac DWP 26200.
Users here told me that the spindles are heavy and STRONGLY suggested that the Dewault was the way to go
The LR was designed to use the Dewault
If you look for the Shaoeko - a commercial small format CNC they also use the Dewault - they must be a very good reason ...... It works and is reliable!
My only problem is the friggin' noise the Dewault will emit in use, I wanted to get a spindle because the LR is a stepping stone machine for me in order to make a bigger faster machine which would need a spindle but the added grief of the water pipes and VFD cabling is just not worth it.
The machine has limitations, of course it does, but it’s only (approx) £400, with it you can recoup your money and move on to bigger and better.
Lastly, if I can find some spacers I will let you know
Matt, as far as I understand, the Router’s motor is NOT the main noise source, but the cutting itself or the shopvac for the dust collector/collection system…
