Gcode Help - Estlcam to Easel
Hoping to get a slight bit of help here. Short story long.
I am trying to do a 3D carve that I have wanted to do for a long time. Fusion360 is being dumb, no clue why. I cannot get it to calculate the tool paths. It is a rather large STL and I know Fusion doesn’t like a bunch of triangles. I’ve tried the mesh reduce. I’ve tried deleting in blender and converting to quad mesh. Estlcam wont even load the STL. Really been down the rabbit hole here.
At this point I have gotten Easel to do what I want it to do I think. I have to pay for Easel Pro but I can stomach that if I can get it to work. My last hurdle is the starting Gcode from Easel. I have compared almost identical gcode from Easel and Estlcam and its basically the same. The thing its missing is the z probe and I’m not sure I’m knowledgeable enough to add it from Estlcam gcode file to the Easel gcode file.
Can anyone combine the Z Probe starting Gcode to the Easel Gcode so that I have an example and I don’t destroy anything?
circle_easel output.gcode (50.0 KB)
circl_estlcam output .gcode (1.6 KB)
Before dealing with probing, you have another potential issue. Your Easel code is in inches but your Estlcam code is in millimeters. Some (all?) V1 maintained firmware does not have inch mode enabled. So, you need to either force Easel to output code in millimeters, or do what is necessary to get the firmware to support inches.
I don’t know what control board you are using, so I’m unsure if you need everything, but here is my best educated guess about your start code assuming millimeters:
G21 ; Sets to millimeter mode
G90 ; Absolute positioning
G94 ; Feedrate to mm/min
G92 X0 Y0 ; Set the current router position as the job origin
; ---Start of probing code
M0 (MSG Attach probe)
G38.2 Z-80 F200 P0.5 ( probe down set thickness )
G1 Z10 F900
M0 (MSG Remove probe)
; ---End of probing code
M62 P0 ( start spindle pin26 )
If you are using the M62 to start your spindle, you will need a matching M63 in the end code to stop the spindle.
Wow, lots of good info here.
I am using the Jackpot on a LR3. I did notice that the Easel code was in inches via the G21 vs G20. But I did not know that V1 firmware only accepts millimeters.
No spindle, just a Makita so no need for the M62 but that makes sense.
Assuming I can fix the mm/in issue. Where would you insert your probe code in the Easel file?
G20
G90
G1 Z0.15000 F9.0
G0 X2.00989 Y1.96704
G1 Z-0.12500 F15.0
G1 X2.02097 Y1.97284 F15.0
G1 X2.03012 Y1.98367 F15.0
Thats the first 7 lines of the Easel code and I don’t know where the probe section should go. After the G90?
Ok well that was an easy fix. I think…
There’s a toggle in Easel. Seems correct now.
Just need to know which line to insert the probe code and if there’s any lines in the easel code that would interfere with the probing.
Circle_Easel_mm.gcode (21.6 KB)
I’m pretty sure he gave you the G codes needed for probing in his answer above. Here’s a quote:
Don’t forget to edit for the thickness of your touch plate in the line that says “probe down set thickness” —
The first part of the command, G38.2, tells it to probe.
The second part, Z, tells it it’s the Z axis.
The third part, -80, tells it that it has a probe to target travel range of 80 mm.
The fourth part, F200, tells it the speed at which to probe.
The final part, P0.5, tells it the plate thickness.
I’m not sure why there’s different information in the parentheses afterwards, but be aware that for some G code commands, what is in parentheses is a comment for your benefit (and could be displayed on a screen if setup for it) and that is ignored by the machine, while in a few certain G code commands, at least in FluidNC, the machine pays attention to what is in the parentheses.
The next two lines of code will move your machine upwards by 10 mm after making contact with the touchplate, and then pause the G code execution to give you time to remove the probe equipment and tell your screen that you want to continue.
He 100% did.
But I don’t think I’m explaining my question right. Sorry for the confusion. I understand the probe code and what it does. What I don’t understand is where I add it to the completed Easel gcode, which line do I insert it.
So the beginning of the Easel code is this:
G21
G90
G1 Z3.810 F228.6
G0 X51.053 Y49.967
G1 Z-3.100 F381.0
G1 X51.353 Y50.128 F381.0
G1 X51.570 Y50.395 F381.0
G1 X51.666 Y50.705 F381.0
G1 X51.633 Y51.057 F381.0
G1 X51.478 Y51.346 F381.0
G1 X51.209 Y51.569 F381.0
Im trying to figure out where to insert the probe gcode.
So should it look like this?
G21
G90
; —Start of probing code
G1 Z10 F900
*; —End of probing code *
G1 Z3.810 F228.6
G0 X51.053 Y49.967
G1 Z-3.100 F381.0
Ah, got it. Sorry I must have misread your question.
I think that looks OK!
If you can, insert the code in the order I listed above. The problem is that Estlcam may insert some of the commands automatically, and I don’t know how it inserts the “Start Code.” I’m away from my main computer, so I cannot test Estlcam. I suspect the G21 and the G90 are added automatically, and perhaps the G94 as well. Note I picked the order so that the correct environment (units, feedrate) are set before the probe is executed.
Good news is it was! That code did exactly as expected! I can press forward!
Thank you, @DougJoseph and @robertbu
Cool!
