I made something some of you that do coding in VS Code may find useful, especially if you use, or previously used, Natizyskunk’s sftp sync extension for VS Code. As you may know, he’s stopped maintaining it, and recently its ability to download / sync from remote to local, got broken by an SSH2 issue. So, since I already needed to fork it to do a couple of other things, I fixed that while I was at it.
Re. “couple of other things” the main one was, I was building a way to automatically generate a list of approved code pages and send it to a secure folder on my server, located above the public html folder, and a way for an auto-scanner to read it, and alert me by email if any of my code pages gets edited or deleted without my knowledge, or any new code pages get added to my server without my knowledge. This meant I needed a beforeUpload hook in the SFTP process. So I gained the hook, and got the download fixed, and also added an auto writing of a persistent log to the project folder, of what got synced and when.
PS: forgot to mention, I also added support for case sensitive discernment of syncing, so that, for example, pulling down C3/ and c3/ from a case sensitive server, to a case insensitive local drive, can be done without having one folder/file clobber the other folder/file (you can setup case sensitive ignore entries). See caseSensitivePatterns
SFTP (watchlist fork)
A fork of Natizyskunk/vscode-sftp by @DougJoseph, branched from release v1.16.3. Not published to the VS Code marketplace — install the .vsix from Releases.
It adds three things to the upstream extension:
- A fix for downloads failing with
isDate is not a functionon current VS Code — see immediately below. This one is likely why you are reading this. beforeUpload— a shell command run to completion before any local → remote transfer, which aborts the transfer if it fails.- A persistent on-disk transfer log, because the Output panel clears and takes the record of what you pushed with it.
Everything else is upstream’s, unchanged. The original README follows below the fork documentation.
Fixed: downloads fail with TypeError: isDate is not a function
Symptom. Any download or remote → local sync fails. Uploads keep working, which is why this can go unnoticed for a long time. The stack looks like this:
at attrsToBytes (…/node_modules/ssh2/lib/protocol/SFTP.js:2492:45)
at SFTP.open (…/node_modules/ssh2/lib/protocol/SFTP.js:331:15)
at ReadStream.open (…/node_modules/ssh2/lib/protocol/SFTP.js:3706:13)
at SFTP.createReadStream (…/node_modules/ssh2/lib/protocol/SFTP.js:305:12)
Cause. ssh2 1.13.0 — the version pinned by upstream v1.16.3 — begins SFTP.js with:
const { inherits, isDate } = require('util');
util.isDate was deprecated years ago and has since been removed from the Node build that current VS Code ships. So isDate is undefined, and calling it throws. The failing call sits on the read path, which is why uploads are unaffected.
This affects the stock extension too. It is not introduced by this fork. Verified by enabling Natizyskunk.sftp 1.16.3 and reproducing the identical error from its own copy of ssh2 1.13.0, at the same line.
The fix. ssh2 1.17.0 corrects it upstream —
const { inherits, types: { isDate } } = require('util');
— so this fork moves the dependency from ^1.13.0 to ^1.17.0. No extension code needed changing. If you would rather stay on the stock extension, bumping ssh2 and rebuilding it yourself fixes it the same way.
beforeUpload
A shell command run to completion before any local → remote transfer begins. A non-zero exit aborts the transfer.
"beforeUpload": "./scripts/prepare-upload.sh",
"beforeUploadTimeout": 120000 // ms; default 120000
- Runs for
upload,upload file,upload folderandsync local ➞ remoteonly. Downloads andsync remote ➞ localnever trigger it. - Runs once per command, not once per file — a folder upload recurses below this point.
- Runs before any connection is opened, so an abort means nothing was transferred.
- Fails closed: a non-zero exit, a timeout, or a failure to spawn all abort the transfer and surface the reason. This is deliberate — a hook that failed open would let a push proceed without whatever the hook was supposed to produce.
- Working directory is the local root of the config in use.
The command receives these environment variables, so one script can serve several configs:
| Variable | Meaning |
SFTP_LOCAL_BASE |
Local root of the config in use |
SFTP_REMOTE_PATH |
That config’s remotePath |
SFTP_HOST |
Target host |
SFTP_PROFILE |
Profile or context name, blank if the config has none |
SFTP_TARGET_LOCAL |
The file or folder acted on, locally |
SFTP_TARGET_REMOTE |
Its remote counterpart |
SFTP_OPERATION |
Which handler fired, e.g. upload file |
Worked example
1. Write the script. Anywhere you like; a relative path in sftp.json resolves against the config’s local root, because that is the working directory the command runs in.
scripts/prepare-upload.sh:
#!/bin/bash
set -euo pipefail
# Whatever has to be true before files leave this machine. Exit non-zero to stop the push.
echo "preparing $SFTP_OPERATION for profile '${SFTP_PROFILE:-none}'"
echo " local root : $SFTP_LOCAL_BASE"
echo " target : $SFTP_TARGET_LOCAL"
echo " going to : $SFTP_HOST:$SFTP_REMOTE_PATH"
# e.g. generate a manifest of what is about to be sent
# find "$SFTP_LOCAL_BASE" -type f -print0 | xargs -0 shasum -a 256 > /tmp/manifest.txt
echo "ok"
2. Make it executable. A script without the executable bit fails to spawn, and because the hook fails closed that aborts every push from this config until it is fixed:
chmod +x scripts/prepare-upload.sh
3. Point the config at it, in that folder’s .vscode/sftp.json:
"host": "example.com",
"remotePath": "/var/www/site",
4. Reload the VS Code window. The extension caches sftp.json at load, so an edit does not take effect until you do.
5. Confirm it is actually wired, which takes about a minute:
- Set
"beforeUpload": "echo hello"and upload any file. The Output panel should showbeforeUpload ➞ running …, thenbeforeUpload output: hello, thenbeforeUpload ✓ ok— all before thelocal ➞ remoteline. - Then set
"beforeUpload": "exit 3"and upload again. You should get an error naming exit 3, and nolocal ➞ remoteline at all. That absence is the proof it fails closed. - Reload between each change, then put your real command back.
The transfer log
Upstream logs only to the VS Code Output panel, which clears — so after a sync there is no record on disk of what went where. This fork writes the same lines to a monthly file inside the local folder the running config governs:
<config local root>/sftp-transfer-logs/sftp-transfer-YYYY-MM.log
"transferLog": true, // default true; false disables it for this config
"transferLogKeepMonths": 24 // older monthly files are deleted
- Monthly files rather than numbered rotation, so “what happened on 15 August” is a filename rather than a search.
- Written per config, so each project’s transfers land in that project’s own log.
- Log lines carry a four-digit year, which the Output panel’s own stamp omits.
- Lines emitted outside an operation — activation, config loading — belong to no project and stay panel-only.
Add /sftp-transfer-logs to the ignore list of every sftp.json that uses this. The folder sits inside a synced tree, so without that entry it would upload itself.
Installing this fork
- Download the
.vsixfrom Releases. code --install-extension sftp-watchlist-<version>.vsix- Disable the stock SFTP extension if you have it — both register the same
sftp.*command ids, and having both enabled makes the second one to load fail every registration. Disable rather than uninstall, so reverting is one click. - Reload the window.
Your existing sftp.json files work unchanged: the command ids, menus, keybindings and config schema are all the same as upstream.
Building from source
git clone https://github.com/DougJoseph/vscode-sftp.git
cd vscode-sftp
git checkout watchlist
npm install
npm run compile
npx @vscode/vsce package
Two things worth knowing before you start:
- Branch from the release tag, not
develop. Upstream’sdevelopdoes not compile — it has a missing import insrc/commands/abstract/createCommand.tsand avscode-uriexport mismatch insrc/helper/paths.ts. This fork branches from tagv1.16.3, which builds clean. - The
packagescript calls the legacyvsce, which is not a dependency here. Usenpx @vscode/vsce packageas above.
