Foil cage
I was wondering if it is a problem to cage the MPCNC with a
“foil cage” to have a dust free less duty atmosphere in my
workspace because the budget is at its end I tought about
using foil and a few wood supports to cage in the drone.
I would of course leave the electronics as far as possible outside.
Would you have concerns? should the motors get dust caps on the bottom?
Kind regards
Moritz
I think you would be fine, between every job just get in there an vacuum off all the funk and you should be fine.
I too want to make an enclosure. Anyone ever try some sort of acrylic frame over the entire thing? That would be sweet
thank you Ryan.
Ill guess Ill give it a shot, soon as I have everything together
