Foam Plug Machining?
HI I have only recently found out about the MPCNC as I was looking for a diy cnc to machine a foam plug for a project that I am working on. I figured the I could ask here if this machine(MPCNC) could be configured for my use.
I apologize if this is the wrong place, but this seemed the most suitable. I was originally going to shape a foam plug by hand, but I would much rather CNC machine it. I am building a 9.5 ft long plug for a streamlined recumbent bike to break the land speed record for a person under 18. The plug will be used to take molds from.
I would need a 4x4ft work area with the parts being 6in tall. Does anyone think this machine could be suitable for my application? I am only machining foam sheets.
Yeah, I think you can go with either machine with foam. LowRider might be a better choice though.
Some food for thought.
When I was on FSAE we almost bought our own shop router and my idea was to machine our body plugs 1 layer at a time (our molds were all made of 3/4" MDF) by using dowel pins (or similar) to align each layer to the next. Any inaccuracies would be easily sanded out, which you’ll likely be doing anyway.
I still think this idea would work great–especially as long as the parts were designed for 3 axis machining. (IE, if you can see all machined surfaces looking at the mold from the top down)
Benefits:
  1. machine 1 layer at a time instead of the entire plug--if you need to take a break from watching the machine it's a lot more convenient
  2. tool length becomes a non-issue
  3. if you make a mistake you'll lose a lot less time/material
So Tim you would recommend the MPCNC? I would definitely be doing it sheet by sheet in 2in foam board, if not 2 sheets stacked one on top of the other once I get it going.
I am leaning towards the MPCNC over the low rider because I don’t want a 4x4 machine forever, just long enough to complete this projects, then make it smaller. I know the low rider is able to do full sheet processing, but I don’t have the floor space for a 4x8 CnC.
I guess what I am really asking is will the mpcnc work OK if it is scaled up to 4x4ft work area. I may need to use mid span supports but that is OK.
I can’t speak to the foam specific question for your use (although I have a feeling it’s perfectly suited). However on the size question I’m certain you’ll be fine. Mine is 48" X 34" physical which gives me a working area of 40" X 25" give or take (I’ve never measured to be honest - as long as I got 20" X 40" I was good). I don’t see any discernible issue on the 48" span in terms of sag.
I did however build up my machine using the thick walled stainless tube. If you go this route make sure you buy thin walled tube for the z-axis as it’s more than rigid enough and makes assembly easier. Much easier. The nut traps fit and you don’t need to drill your way through as much stainless.
Either will work if you are moving down to 2" foam. You originally said 6", meaning a min of 12" Z. 2" is a significantly different work load.
The LowRider does not NEED to be 4’x8’, mine is 2’x4’.
