FluidNC and MKS TinyBee
Finally got around to giving this board a try and so far it has passed all the checks and successfully made some cuts on my Primo. A bit more tuning to go, but overall I think this is a great option. I’ve got the probe working using the TB input (with the help from some folks at FluidNC).
Config is mostly based on what @ relytjames has above and some things taken from fluidnc wiki.
board: MKS TinyBee V1.0 XXYYZ
kinematics:
  Cartesian:
i2so:
  bck_pin: gpio.25
  data_pin: gpio.27
  ws_pin: gpio.26
spi:
  miso_pin: gpio.19
  mosi_pin: gpio.23
  sck_pin: gpio.18
sdcard:
  cs_pin: gpio.5
  card_detect_pin: NO_PIN
stepping:
  engine: I2S_STATIC
  idle_ms: 255
  pulse_us: 4
  dir_delay_us: 1
  disable_delay_us: 2
axes:
  x:
    steps_per_mm: 100.000
    max_rate_mm_per_min: 8000.000
    max_travel_mm: 600.000
    soft_limits: true
    homing:
      cycle: 0
      positive_direction: false
      mpos_mm: 0.000
      feed_mm_per_min: 300.000
      seek_mm_per_min: 1500.000
      settle_ms: 500
      seek_scaler: 1.100
      feed_scaler: 1.100
    motor0:
      limit_neg_pin: gpio.33:high
      hard_limits: true
      pulloff_mm: 4.000
      stepstick:
        step_pin: I2SO.1
        direction_pin: I2SO.2
        disable_pin: I2SO.0
    # use E0 driver for 2nd X axis motor
    motor1:
      limit_neg_pin: gpio.22:high
      hard_limits: true
      pulloff_mm: 4.000
      stepstick:
        step_pin: I2SO.10
        direction_pin: I2SO.11
        disable_pin: I2SO.9
  y:
    acceleration_mm_per_sec2: 70.000
    max_travel_mm: 440.000
    soft_limits: true
    homing:
      cycle: 0
      mpos_mm: 0.000
      settle_ms: 500
      seek_scaler: 1.100
      feed_scaler: 1.100
    motor0:
      limit_neg_pin: gpio.32:high
      hard_limits: true
      pulloff_mm: 4.000
      stepstick:
        step_pin: I2SO.4
        direction_pin: I2SO.5
        disable_pin: I2SO.3
    # use E1 driver for 2nd Y axis motor
    motor1:
      limit_neg_pin: gpio.35:high
      hard_limits: true
      pulloff_mm: 4.000
      stepstick:
        step_pin: I2SO.13
        direction_pin: I2SO.14
        disable_pin: I2SO.12
  z:
    steps_per_mm: 400.000
    acceleration_mm_per_sec2: 60.000
    max_travel_mm: 80.000
    soft_limits: false
    homing:
      cycle: 0
      mpos_mm: 0.000
      seek_mm_per_min: 500.000
      settle_ms: 500
      seek_scaler: 1.100
      feed_scaler: 1.100
    motor0:
      pulloff_mm: 3.000
      stepstick:
        step_pin: I2SO.7
        direction_pin: I2SO.8
        disable_pin: I2SO.6
relay:
  direction_pin: NO_PIN
  output_pin: i2so.17
  enable_pin: NO_PIN
  disable_with_s0: false
  s0_with_disable: true
  spinup_ms: 0
  spindown_ms: 0
  tool_num: 0
  speed_map: 0=0.000% 0=100.000% 1=100.000%
  off_on_alarm: false
probe:
  # this is the TB input
  pin: gpio.39:low
control:
  safety_door_pin: NO_PIN
  reset_pin: NO_PIN
  feed_hold_pin: NO_PIN
  cycle_start_pin: NO_PIN
  macro0_pin: NO_PIN
  macro1_pin: NO_PIN
  macro2_pin: NO_PIN
  macro3_pin: NO_PIN
user_outputs:
  analog0_pin: NO_PIN
  analog1_pin: NO_PIN
  analog2_pin: NO_PIN
  analog3_pin: NO_PIN
  analog0_hz: 5000
  analog1_hz: 5000
  analog2_hz: 5000
  analog3_hz: 5000
  digital0_pin: NO_PIN
  digital1_pin: NO_PIN
  digital2_pin: NO_PIN
  digital3_pin: NO_PIN
start:
  must_home: false
Motors are X1, Y1, X2, Y2, Z.
Limit switches are x1, y1, x2, y2 and use the S and G pins (left two pins).
P is the z probe.
The spindle relay is still untested.
