About to start my first build, the Lowrider V4. I see the JP1 and JP3 are out of stock, and the JP2 has warnings about not being for beginners and there is some sort of issue that was corrected by hand. In this case, what board should I get? Should I be looking elsewhere for a board? I would like to add a hand pendant and/or a touch screen, if that makes a difference. Thanks in advance for the help.
JP3 is what comes with the kit now. I see Ryan is out of stock but I believe he has some coming real soon. If you don’t ever plan to run a laser on your machine then the JP2 should work just fine if you don’t want to wait for the 3 to come in stock.
Welcome to the forum! Hopefully you will stick around and start a build thread!
Thanks for the quick response! I may just wait to get the most up-to-date board. Can’t rule out the possibility of adding a laser down the road ![]()
Hopefully tomorrow evening. I just got an email…at least I think it is the board shipment.
