My first import of a F360 DXF file transferred over in what seems to be out of scale, and only 1 insert out of 30 insert holes copied. Any advice would be welcome !
- Did you design it in mm?
- Did you export it in mm?
- Did you select mm when you imported it?
- Were all of the holes in the same sketch, and were they all closed geometry?
If you would like to send me the dxf, I can look at it and see if there is anything I can find wrong.
I’ve had trouble when I import dxfs into etslcam that had components grouped together. I just save a good copy, ungroup everything, and then export it again. I was using librecad at the time.
Right click on the face of the design and create a new sketch. Then export that sketch as your DXF. I’m betting the sketch2 only has the single hole on it prior to you creating the grid.
