The steppers on my Lowrider2 have always run a little hot, the Z-steppers ran really hot. I must have missed the heat/melt damage when I last moved.
There are a number of similar posts on the forum. I had been running the Marlin_V1CNC_Rambo_DualLR_2.0.9.2_513 firmware on a Rambo 1.4a board from Ryan. One of the posts, Stepper Hot fix, provides a recommendation to fix the problem. I would also like to update the dimensions in the firmware, as when I Home (G28), it generates a machine stop.
The doc on the website suggests that the latest firmware is on Github - GitHub - V1EngineeringInc/MarlinBuilder: MarlinBuilder . However, I vaguely remember there was another Github project that was referenced that had the latest DualLR firmware pre-built. The MarlinBuilder doesn’t have the individual firmware builds anymore, but instead has machine setup files, such as src/configs/V1CNC_Rambo_Dual, correct? That is great. I just want to ask, is this the repo that should be used? Second, the last release was September 25, 2022, but the 20 changes since them seem to be relatively insignificant. Just use the source from the release tag?
In comparing the source between 2.0.9.2 on May 4, 2022 Ryan dropped the value of DIGIPOT_MOTOR_CURRENT to 125 from 138, past the 130 value in the post I referenced. So if this is the correct repo, using this new version should solve the heat problem, yes?
On 8/31/2022, Ryan increased the X_BED_SIZE and Y_BED_SIZE so the G28 machine stop should no longer occur, correct? If anything, I can reduce the values to my exact machine size 1092 and 2057 from 1220, 2440, yes? Thank you.
