Firmware Problem?
Hi forum, yesteerday. I had a problem, and maybe you could help me, Here’s what happened:
Yesterday, I was working with it when my colleague moved the PCB (SKR pro) and possibly removed the micro SD card in the middle of the machine’s operation. The machine stopped, and now I can’t establish communication between it and my computer. I’ve been searching for information on the website, but I still have some questions.
My main question is whether removing the SD card could have damaged the machine’s firmware. Is the firmware loaded on the SD card? Or is it stored directly in internal memory on the SKR? I bought the microSD card from V1 store, and now when I open it, it’s empty. Is this normal?
It seems to me more like a software issue (communication problem, as the touchscreen also doesn’t recognize the SKR) rather than a hardware component failure. Right now, I am in Chad (Central Africa), and I have very few days left before I leave. The machine is very important to our team and our recycling project, and if I leave without fixing it, I don’t think they will be able to recover it.
Do you have any idea what the problem might be?
Best regards, and thanks for your help,
Carlos
Is it possible, yes. If you disconnect hardware from a running machine, you can damage it.
Is it likely? No.
You more than likely had multiple things happen when your colleague moved the SKR board.
High resolution pictures of the front and back of your setup would be helpful, along with some basic troubleshooting information:
With the USB disconnected, and the machine powered on, what LEDs light up on the SKR?
Do you use an LCD? If so, what appears on the LCD as you power it up?
If you put the SD card in a reader and put that in another computer, you note it shows up as empty. Very possibly the SD card was corrupted, in which case it may be able to be reformatted.
If the SD card cannot be reformatted, then you’re getting indications that something may have been damaged- but we should troubleshoot further .
What type of machine is this SKR in?
Traducción al inglés:
Hi Jim, thank you for your help. Here’s my response.
When I connect the board to the power, the following LEDs light up:
  • Blue LED that recognizes the SD card.
  • Three orange LEDs for 3.3V, 5V, and 12V.
  • Red LEDs for E2 and Z1 motor drivers, but none for X, Y, E1 (they remain off despite having their cables connected).
On the LCD screen, the startup page displays the following:
V1 Marlin Mode
Marlin
515D 2.1.1
marlinfw.org
When I connect it via USB with my program, I can find the corresponding COM port and establish a connection with the SKR. However, when I send a command to move an axis, the program indicates: “Waiting for command.” The machine does not move, although it does set a 0,0,0 origin (something that doesn’t happen on the LCD).
This is an MPCNC with dual endstops.
I also copied and pasted the firmware.bin file to flash the board onto the SD card (it is the only file on the SD). I re-inserted the SD card, but this file has neither changed its name nor its extension after doing this.
Visually, the board looks fine; it doesn’t seem to have any damaged, burnt, or cracked components. There are no smells or liquids. The three fuses are in good condition. I have attached photos.
Thanks again for your help,
Carlos
Good news, the board firmware is alive. No need to try and flash any firmware at the moment.
Send the board an M503 , an M122, and a M119. Send these in the as-is state first, then again after the note below. Report both sets of results.
Here’s a clue. You don’t have working drivers in the locations with no LED.
Power down the SKR, and remove everything except the incoming pair of power wires.
Power back up.
Repeat the M commands from above and also note the LED status indicators from the stepper drivers when you power back up.
Hi there!
I think we are in the good direction, now I have een able to move the CNC with my program, but there are still some motors that are not working. I send you the results of both tests (with and without the wires attached)
Right now, all 6 LEDS (X, Y, Z1, E0, E1, E2) are on.
21:24:26.713 : No start signal detected - forcing start
21:24:26.807 : FIRMWARE_NAME:Marlin 515D 2.1.1 (Sep 25 2022 17:41:33) SOURCE_CODE_URL:github.com/MarlinFirmware/Marlin PROTOCOL_VERSION:1.0 MACHINE_TYPE:V1CNC 515D EXTRUDER_COUNT:0 UUID:cede2a2f-41a2-4748-9b12-c55c62f367ff
21:24:26.807 : Cap:SERIAL_XON_XOFF:0
21:24:26.807 : Cap:BINARY_FILE_TRANSFER:0
21:24:26.807 : Cap:EEPROM:1
21:24:26.807 : Cap:VOLUMETRIC:0
21:24:26.807 : Cap:AUTOREPORT_POS:1
21:24:26.807 : Cap:AUTOREPORT_TEMP:0
21:24:26.807 : Cap:PROGRESS:0
21:24:26.807 : Cap:PRINT_JOB:1
21:24:26.807 : Cap:AUTOLEVEL:0
21:24:26.807 : Cap:RUNOUT:0
21:24:26.807 : Cap:Z_PROBE:0
21:24:26.807 : Cap:LEVELING_DATA:0
21:24:26.807 : Cap:BUILD_PERCENT:0
21:24:26.807 : Cap:SOFTWARE_POWER:0
21:24:26.807 : Cap:TOGGLE_LIGHTS:0
21:24:26.807 : Cap:CASE_LIGHT_BRIGHTNESS:0
21:24:26.807 : Cap:EMERGENCY_PARSER:1
21:24:26.807 : Cap:HOST_ACTION_COMMANDS:1
21:24:26.807 : Cap:PROMPT_SUPPORT:1
21:24:26.807 : Cap:SDCARD:1
21:24:26.807 : Cap:MULTI_VOLUME:0
21:24:26.807 : Cap:REPEAT:0
21:24:26.807 : Cap:SD_WRITE:1
21:24:26.807 : Cap:AUTOREPORT_SD_STATUS:1
21:24:26.807 : Cap:LONG_FILENAME:0
21:24:26.807 : Cap:LFN_WRITE:0
21:24:26.807 : Cap:CUSTOM_FIRMWARE_UPLOAD:0
21:24:26.807 : Cap:EXTENDED_M20:0
21:24:26.807 : Cap:THERMAL_PROTECTION:1
21:24:26.807 : Cap:MOTION_MODES:1
21:24:26.807 : Cap:ARCS:1
21:24:26.807 : Cap:BABYSTEPPING:1
21:24:26.807 : Cap:CHAMBER_TEMPERATURE:0
21:24:26.807 : Cap:COOLER_TEMPERATURE:0
21:24:26.807 : Cap:MEATPACK:0
21:24:26.807 : Cap:CONFIG_EXPORT:0
21:24:26.807 : area:{full:{min:{x:0.0000,y:0.0000,z:0.0000},max:{x:1220.0000,y:2440.0000,z:200.0000}},work:{min:{x:0.0000,y:0.0000,z:0.0000},max:{x:1220.0000,y:2440.0000,z:200.0000}}}
21:24:26.885 : X:0.0000 Y:0.0000 Z:0.0000 Count X:0 Y:0 Z:0
21:24:26.885 : echo:Unknown command: “M221 S100”
21:24:26.885 : echo:DEBUG:INFO,ERRORS
21:24:26.885 : echo:No media
21:24:26.885 : echo:Unknown command: “M80”
21:33:57.947 : Preferred name from C:\Users\Fej\Desktop\CNC\FYA.gcode to FYA
21:34:52.358 : Communication timeout - reset send buffer block
21:35:39.660 : Un périphérique attaché au système ne fonctionne pas correctement.
21:35:39.660 :
21:36:06.712 : No start signal detected - forcing start
21:36:06.790 : FIRMWARE_NAME:Marlin 515D 2.1.1 (Sep 25 2022 17:41:33) SOURCE_CODE_URL:github.com/MarlinFirmware/Marlin PROTOCOL_VERSION:1.0 MACHINE_TYPE:V1CNC 515D EXTRUDER_COUNT:0 UUID:cede2a2f-41a2-4748-9b12-c55c62f367ff
21:36:06.790 : Cap:SERIAL_XON_XOFF:0
21:36:06.790 : Cap:BINARY_FILE_TRANSFER:0
21:36:06.790 : Cap:EEPROM:1
21:36:06.790 : Cap:VOLUMETRIC:0
21:36:06.790 : Cap:AUTOREPORT_POS:1
21:36:06.790 : Cap:AUTOREPORT_TEMP:0
21:36:06.790 : Cap:PROGRESS:0
21:36:06.790 : Cap:PRINT_JOB:1
21:36:06.790 : Cap:AUTOLEVEL:0
21:36:06.790 : Cap:RUNOUT:0
21:36:06.790 : Cap:Z_PROBE:0
21:36:06.790 : Cap:LEVELING_DATA:0
21:36:06.790 : Cap:BUILD_PERCENT:0
21:36:06.790 : Cap:SOFTWARE_POWER:0
21:36:06.790 : Cap:TOGGLE_LIGHTS:0
21:36:06.790 : Cap:CASE_LIGHT_BRIGHTNESS:0
21:36:06.790 : Cap:EMERGENCY_PARSER:1
21:36:06.790 : Cap:HOST_ACTION_COMMANDS:1
21:36:06.790 : Cap:PROMPT_SUPPORT:1
21:36:06.790 : Cap:SDCARD:1
21:36:06.790 : Cap:MULTI_VOLUME:0
21:36:06.790 : Cap:REPEAT:0
21:36:06.790 : Cap:SD_WRITE:1
21:36:06.790 : Cap:AUTOREPORT_SD_STATUS:1
21:36:06.790 : Cap:LONG_FILENAME:0
21:36:06.790 : Cap:LFN_WRITE:0
21:36:06.790 : Cap:CUSTOM_FIRMWARE_UPLOAD:0
21:36:06.790 : Cap:EXTENDED_M20:0
21:36:06.790 : Cap:THERMAL_PROTECTION:1
21:36:06.790 : Cap:MOTION_MODES:1
21:36:06.790 : Cap:ARCS:1
21:36:06.790 : Cap:BABYSTEPPING:1
21:36:06.790 : Cap:CHAMBER_TEMPERATURE:0
21:36:06.790 : Cap:COOLER_TEMPERATURE:0
21:36:06.790 : Cap:MEATPACK:0
21:36:06.790 : Cap:CONFIG_EXPORT:0
21:36:06.790 : area:{full:{min:{x:0.0000,y:0.0000,z:0.0000},max:{x:1220.0000,y:2440.0000,z:200.0000}},work:{min:{x:0.0000,y:0.0000,z:0.0000},max:{x:1220.0000,y:2440.0000,z:200.0000}}}
21:36:06.790 : X:0.0000 Y:0.0000 Z:0.0000 Count X:0 Y:0 Z:0
21:36:06.790 : echo:Unknown command: “M221 S100”
21:36:06.790 : echo:DEBUG:INFO,ERRORS
21:36:06.790 : echo:No media
21:36:06.790 : echo:Unknown command: “M80”
21:36:24.429 : echo:; Linear Units:
21:36:24.429 : echo: G21 ; (mm)
21:36:24.429 : echo:; Temperature Units:
21:36:24.429 : echo: M149 C ; Units in Celsius
21:36:24.429 : echo:; Steps per unit:
21:36:24.429 : echo: M92 X100.0000 Y100.0000 Z400.0000
21:36:24.429 : echo:; Max feedrates (units/s):
21:36:24.429 : echo: M203 X50.0000 Y50.0000 Z15.0000
21:36:24.429 : echo:; Max Acceleration (units/s2):
21:36:24.429 : echo: M201 X180.0000 Y180.0000 Z80.0000
21:36:24.429 : echo:; Acceleration (units/s2) (P R T):
21:36:24.429 : echo: M204 P180.0000 R3000.0000 T180.0000
21:36:24.429 : echo:; Advanced (B<min_segment_time_us> S<min_feedrate> T<min_travel_feedrate> J<junc_dev>):
21:36:24.429 : echo: M205 B20000.0000 S0.0000 T0.0000 J0.0400
21:36:24.429 : echo:; Home offset:
21:36:24.429 : echo: M206 X0.0000 Y0.0000 Z0.0000
21:36:24.429 : echo:; Endstop adjustment:
21:36:24.429 : echo: M666 X0.0000
21:36:24.429 : Y0.0000
21:36:24.429 : echo:; Stepper driver current:
21:36:24.429 : echo: M906 X900 Y900 Z900
21:36:24.429 : echo: M906 I1 X900 Y900
21:36:24.429 : echo:; Driver stepping mode:
21:36:45.287 : X X2 Y Y2 Z
21:36:45.287 : Address 0 0 0 0 0
21:36:45.412 : Enabled false false false false false
21:36:45.412 : Set current 900 900 900 900 900
21:36:45.490 : RMS current 1602 887 1602 887 1602
21:36:45.569 : MAX current 2259 1251 2259 1251 2259
21:36:45.569 : Run current 28/31 28/31 28/31 28/31 28/31
21:36:45.569 : Hold current 22/31 22/31 22/31 22/31 22/31
21:36:45.647 : CS actual 0/31 22/31 0/31 22/31 0/31
21:36:45.647 : PWM scale
21:36:45.725 : vsense 0=.325 1=.18 0=.325 1=.18 0=.325
21:36:45.803 : stealthChop false false false false false
21:36:45.881 : msteps 256 16 256 16 256
21:36:45.943 : interp false true false true false
21:36:46.022 : tstep 0 max 0 max 0
21:36:46.022 : PWM thresh.
21:36:46.022 : [mm/s]
21:36:46.100 : OT prewarn false false false false false
21:36:46.100 : triggered
21:36:46.100 : OTP false false false false false
21:36:46.178 : pwm scale sum 0 25 0 25 0
21:36:46.256 : pwm scale auto 0 0 0 0 0
21:36:46.334 : pwm offset auto 0 36 0 36 0
21:36:46.412 : pwm grad auto 0 14 0 14 0
21:36:46.475 : off time 0 3 0 3 0
21:36:46.553 : blank time 16 24 16 24 16
21:36:46.553 : hysteresis
21:36:46.631 : -end -3 -1 -3 -1 -3
21:36:46.709 : -start 1 1 1 1 1
21:36:46.709 : Stallguard thrs 0 0 0 0 0
21:36:46.787 : uStep count 0 56 0 56 0
21:36:46.787 : DRVSTATUS X X2 Y Y2 Z
21:36:46.865 : sg_result 0 0 0 0 0
21:36:46.943 : stst * * *
21:36:47.006 : olb * *
21:36:47.084 : ola * *
21:36:47.162 : s2gb
21:36:47.240 : s2ga
21:36:47.318 : otpw
21:36:47.397 : ot
21:36:47.475 : 157C
21:36:47.553 : 150C
21:36:47.615 : 143C
21:36:47.693 : 120C
21:36:47.771 : s2vsa
21:36:47.850 : s2vsb
21:36:47.850 : Driver registers:
21:36:47.865 : X 0x00:00:00:00 Bad response!
21:36:47.881 : X2 0x80:16:00:C0
21:36:47.896 : Y 0x00:00:00:00 Bad response!
21:36:47.912 : Y2 0x80:16:00:C0
21:36:47.928 : Z 0x00:00:00:00 Bad response!
21:36:47.943 : Testing X connection… Error: All LOW
21:36:47.959 : Testing X2 connection… OK
21:36:47.975 : Testing Y connection… Error: All LOW
21:36:47.975 : Testing Y2 connection… OK
21:36:48.006 : Testing Z connection… Error: All LOW
21:37:32.503 : X X2 Y Y2 Z
21:37:32.503 : Address 0 0 0 0 0
21:37:32.628 : Enabled false false false false false
21:37:32.628 : Set current 900 900 900 900 900
21:37:32.706 : RMS current 1602 887 1602 887 1602
21:37:32.784 : MAX current 2259 1251 2259 1251 2259
21:37:32.784 : Run current 28/31 28/31 28/31 28/31 28/31
21:37:32.784 : Hold current 22/31 22/31 22/31 22/31 22/31
21:37:32.862 : CS actual 0/31 22/31 0/31 22/31 0/31
21:37:32.862 : PWM scale
21:37:32.940 : vsense 0=.325 1=.18 0=.325 1=.18 0=.325
21:37:33.018 : stealthChop false false false false false
21:37:33.081 : msteps 256 16 256 16 256
21:37:33.159 : interp false true false true false
21:37:33.237 : tstep 0 max 0 max 0
21:37:33.237 : PWM thresh.
21:37:33.237 : [mm/s]
21:37:33.315 : OT prewarn false false false false false
21:37:33.315 : triggered
21:37:33.315 : OTP false false false false false
21:37:33.393 : pwm scale sum 0 25 0 25 0
21:37:33.471 : pwm scale auto 0 0 0 0 0
21:37:33.550 : pwm offset auto 0 36 0 36 0
21:37:33.628 : pwm grad auto 0 14 0 14 0
21:37:33.690 : off time 0 3 0 3 0
21:37:33.768 : blank time 16 24 16 24 16
21:37:33.768 : hysteresis
21:37:33.846 : -end -3 -1 -3 -1 -3
21:37:33.925 : -start 1 1 1 1 1
21:37:33.925 : Stallguard thrs 0 0 0 0 0
21:37:34.003 : uStep count 0 56 0 56 0
21:37:34.003 : DRVSTATUS X X2 Y Y2 Z
21:37:34.081 : sg_result 0 0 0 0 0
21:37:34.159 : stst * * *
21:37:34.237 : olb * *
21:37:34.300 : ola * *
21:37:34.378 : s2gb
21:37:34.456 : s2ga
21:37:34.534 : otpw
21:37:34.612 : ot
21:37:34.690 : 157C
21:37:34.768 : 150C
21:37:34.831 : 143C
21:37:34.909 : 120C
21:37:34.987 : s2vsa
21:37:35.065 : s2vsb
21:37:35.065 : Driver registers:
21:37:35.081 : X 0x00:00:00:00 Bad response!
21:37:35.096 : X2 0x80:16:00:C0
21:37:35.112 : Y 0x00:00:00:00 Bad response!
21:37:35.128 : Y2 0x80:16:00:C0
21:37:35.143 : Z 0x00:00:00:00 Bad response!
21:37:35.159 : Testing X connection… Error: All LOW
21:37:35.174 : Testing X2 connection… OK
21:37:35.190 : Testing Y connection… Error: All LOW
21:37:35.190 : Testing Y2 connection… OK
21:37:35.221 : Testing Z connection… Error: All LOW
21:40:06.546 : No start signal detected - forcing start
21:40:06.609 : FIRMWARE_NAME:Marlin 515D 2.1.1 (Sep 25 2022 17:41:33) SOURCE_CODE_URL:github.com/MarlinFirmware/Marlin PROTOCOL_VERSION:1.0 MACHINE_TYPE:V1CNC 515D EXTRUDER_COUNT:0 UUID:cede2a2f-41a2-4748-9b12-c55c62f367ff
21:40:06.609 : Cap:SERIAL_XON_XOFF:0
21:40:06.609 : Cap:BINARY_FILE_TRANSFER:0
21:40:06.609 : Cap:EEPROM:1
21:40:06.609 : Cap:VOLUMETRIC:0
21:40:06.609 : Cap:AUTOREPORT_POS:1
21:40:06.609 : Cap:AUTOREPORT_TEMP:0
21:40:06.609 : Cap:PROGRESS:0
21:40:06.609 : Cap:PRINT_JOB:1
21:40:06.609 : Cap:AUTOLEVEL:0
21:40:06.609 : Cap:RUNOUT:0
21:40:06.609 : Cap:Z_PROBE:0
21:40:06.609 : Cap:LEVELING_DATA:0
21:40:06.609 : Cap:BUILD_PERCENT:0
21:40:06.609 : Cap:SOFTWARE_POWER:0
21:40:06.609 : Cap:TOGGLE_LIGHTS:0
21:40:06.609 : Cap:CASE_LIGHT_BRIGHTNESS:0
21:40:06.609 : Cap:EMERGENCY_PARSER:1
21:40:06.609 : Cap:HOST_ACTION_COMMANDS:1
21:40:06.609 : Cap:PROMPT_SUPPORT:1
21:40:06.609 : Cap:SDCARD:1
21:40:06.609 : Cap:MULTI_VOLUME:0
21:40:06.609 : Cap:REPEAT:0
21:40:06.609 : Cap:SD_WRITE:1
21:40:06.609 : Cap:AUTOREPORT_SD_STATUS:1
21:40:06.609 : Cap:LONG_FILENAME:0
21:40:06.609 : Cap:LFN_WRITE:0
21:40:06.609 : Cap:CUSTOM_FIRMWARE_UPLOAD:0
21:40:06.609 : Cap:EXTENDED_M20:0
21:40:06.609 : Cap:THERMAL_PROTECTION:1
21:40:06.609 : Cap:MOTION_MODES:1
21:40:06.609 : Cap:ARCS:1
21:40:06.609 : Cap:BABYSTEPPING:1
21:40:06.609 : Cap:CHAMBER_TEMPERATURE:0
21:40:06.609 : Cap:COOLER_TEMPERATURE:0
21:40:06.609 : Cap:MEATPACK:0
21:40:06.609 : Cap:CONFIG_EXPORT:0
21:40:06.609 : area:{full:{min:{x:0.0000,y:0.0000,z:0.0000},max:{x:1220.0000,y:2440.0000,z:200.0000}},work:{min:{x:0.0000,y:0.0000,z:0.0000},max:{x:1220.0000,y:2440.0000,z:200.0000}}}
21:40:06.609 : X:0.0000 Y:0.0000 Z:0.0000 Count X:0 Y:0 Z:0
21:40:06.609 : echo:Unknown command: “M221 S100”
21:40:06.640 : echo:DEBUG:INFO,ERRORS
21:40:06.640 : echo:No media
21:40:06.640 : echo:Unknown command: “M80”
21:40:06.656 : echo:DEBUG:INFO,ERRORS
21:40:24.795 : echo:; Linear Units:
21:40:24.795 : echo: G21 ; (mm)
21:40:24.795 : echo:; Temperature Units:
21:40:24.795 : echo: M149 C ; Units in Celsius
21:40:24.795 : echo:; Steps per unit:
21:40:24.795 : echo: M92 X100.0000 Y100.0000 Z400.0000
21:40:24.795 : echo:; Max feedrates (units/s):
21:40:24.795 : echo: M203 X50.0000 Y50.0000 Z15.0000
21:40:24.795 : echo:; Max Acceleration (units/s2):
21:40:24.795 : echo: M201 X180.0000 Y180.0000 Z80.0000
21:40:24.795 : echo:; Acceleration (units/s2) (P R T):
21:40:24.795 : echo: M204 P180.0000 R3000.0000 T180.0000
21:40:24.795 : echo:; Advanced (B<min_segment_time_us> S<min_feedrate> T<min_travel_feedrate> J<junc_dev>):
21:40:24.795 : echo: M205 B20000.0000 S0.0000 T0.0000 J0.0400
21:40:24.795 : echo:; Home offset:
21:40:24.795 : echo: M206 X0.0000 Y0.0000 Z0.0000
21:40:24.795 : echo:; Endstop adjustment:
21:40:24.795 : echo: M666 X0.0000
21:40:24.795 : Y0.0000
21:40:24.795 : echo:; Stepper driver current:
21:40:24.795 : echo: M906 X900 Y900 Z900
21:40:24.795 : echo: M906 I1 X900 Y900
21:40:24.795 : echo:; Driver stepping mode:
21:40:47.168 : X X2 Y Y2 Z
21:40:47.168 : Address 0 0 0 0 0
21:40:47.293 : Enabled false false false false false
21:40:47.293 : Set current 900 900 900 900 900
21:40:47.372 : RMS current 1602 887 1602 887 1602
21:40:47.450 : MAX current 2259 1251 2259 1251 2259
21:40:47.450 : Run current 28/31 28/31 28/31 28/31 28/31
21:40:47.450 : Hold current 22/31 22/31 22/31 22/31 22/31
21:40:47.528 : CS actual 0/31 22/31 0/31 22/31 0/31
21:40:47.528 : PWM scale
21:40:47.606 : vsense 0=.325 1=.18 0=.325 1=.18 0=.325
21:40:47.684 : stealthChop false false false false false
21:40:47.747 : msteps 256 16 256 16 256
21:40:47.825 : interp false true false true false
21:40:47.903 : tstep 0 max 0 max 0
21:40:47.903 : PWM thresh.
21:40:47.903 : [mm/s]
21:40:47.981 : OT prewarn false false false false false
21:40:47.981 : triggered
21:40:47.981 : OTP false false false false false
21:40:48.059 : pwm scale sum 0 25 0 25 0
21:40:48.137 : pwm scale auto 0 0 0 0 0
21:40:48.215 : pwm offset auto 0 36 0 36 0
21:40:48.293 : pwm grad auto 0 14 0 14 0
21:40:48.356 : off time 0 3 0 3 0
21:40:48.434 : blank time 16 24 16 24 16
21:40:48.434 : hysteresis
21:40:48.512 : -end -3 -1 -3 -1 -3
21:40:48.590 : -start 1 1 1 1 1
21:40:48.590 : Stallguard thrs 0 0 0 0 0
21:40:48.668 : uStep count 0 56 0 56 0
21:40:48.668 : DRVSTATUS X X2 Y Y2 Z
21:40:48.746 : sg_result 0 0 0 0 0
21:40:48.825 : stst * * *
21:40:48.887 : olb * *
21:40:48.965 : ola * *
21:40:49.043 : s2gb
21:40:49.121 : s2ga
21:40:49.200 : otpw
21:40:49.278 : ot
21:40:49.356 : 157C
21:40:49.434 : 150C
21:40:49.496 : 143C
21:40:49.575 : 120C
21:40:49.653 : s2vsa
21:40:49.731 : s2vsb
21:40:49.731 : Driver registers:
21:40:49.746 : X 0x00:00:00:00 Bad response!
21:40:49.762 : X2 0x80:16:00:C0
21:40:49.778 : Y 0x00:00:00:00 Bad response!
21:40:49.793 : Y2 0x80:16:00:C0
21:40:49.809 : Z 0x00:00:00:00 Bad response!
21:40:49.825 : Testing X connection… Error: All LOW
21:40:49.840 : Testing X2 connection… OK
21:40:49.856 : Testing Y connection… Error: All LOW
21:40:49.856 : Testing Y2 connection… OK
21:40:49.887 : Testing Z connection… Error: All LOW
21:41:20.166 : Reporting endstop status
21:41:20.166 : x_min: TRIGGERED
21:41:20.166 : x2_min: TRIGGERED
21:41:20.166 : y_min: TRIGGERED
21:41:20.166 : y2_min: TRIGGERED
21:41:20.166 : z_min: open
Hi Jim,
You have already help mea lot, but I am really short of time and I don’t find the solution to my problem. Could you please give me some helpp with the code I sended you? Thank youso much for your help in advance.
Carlos
Somehow I didn’t see your reply, so hadn’t looked at this yet.
What I see consistently in your results is sumarized below
This means that for some reason UART communication between Marlin firmware and the UARTs in your TMC 2209s isnt working properly. That’s what we need to solve.
Hopefully the rest of the community can help with troubleshooting this. Later today I’ll try to go back over the photos you posted. Can you also post high-resolution photos of the tops and undersides of your TMC2209 drivers?
I have a big QB one 3D printer with big tree tech TFT-35 v 2.0 board for the touch screen and a 1.4 turbo for the main board SKR for some reason my firmware is not flashing and I don’t know what I’m doing wrong
