Finger Painting
Yep… cybertruck frunk severed finger youtuber idiot - Google Search
Didn’t think ChatGPT would allow generating machines comprised of severed fingers, but here you go…
Unable to share link to chats with visuals, so, here’s prompts used…
  • Create an image of a CNC machine that paints using a wheel with 6 short paint brushes around the edge of a disk that goes where a router drill normally would be
  • Change the brushed disk orientation to be vertical
  • No, the brushes should look like spokes on a wheel, pointing outwards
  • Replace each brush with a severed finger digit. Put different colored paint on the tip of each finger digit.
    • Used 2nd attempt
  • This is almost perfect. Keep everything the same, just remove the wooden wheel behind finger digits. Add some wet paint to the tip of each finger digit.
    • Used 4th attempt
I’m new to AI stuff. which platform did you use?
Am using OpenAI’s https://chatgpt.com, paid subscription so am able to use their “ChatGPT 4o” model for various personal/work tasks including silly visualizations like this.
Ah. That’s the difference then.
Great way to train the AI to make use of “human resources” in machine design.
@azab2c , too funny. I tried your same prompts on Meta and it baulked at the severed fingers. :crazy_face:
I used my sand table Arrakis 2.0 to make a few paintings. I put acrylic paint on a canvas board then run a pattern so the ball rolls through the paint. I use multiple passes with the same pattern and different paint colors. It leaves a nicely textured surface.
Video here.
Niiice!
That’s pretty cool.
