Hello,
I’ve ordered some 30mm tubing, and I’ll have to make at one rough cut at the store parking lot, since it’s 20 feet long! Which made me realize that I should decide on some final dimensions and source more table parts soon, especially since I like finding stuff cheap/second hand/free/reused from somewhere, which isn’t the fastest way to do things.
If I’ve understood things correctly, you want the X axis to be as short as possible for stability. I want to cut full sheets, so that means 4’ or 1220mm cutting area. I found this old comment from April 2021:
Is the calculator the same as it was back then?
And also, when it comes to Y length, does that affect the CNC accuracy in any way? Sometimes (not often at all) I get access to some 10’ long sheets, although I’d probably do more than fine with an 8’ cutting area. However, if having 2’ longer Y axis doesn’t affect the accuracy in any negative way, then I might as well build it a bit bigger, as I’ve got space for it.
So should I go for something like 1250x2500mm for full sheet capacity? That would mean just 30mm extra X space, and 60mm extra Y space. Or something like 3100mm Y length if it doesn’t make much of a difference.
I’ll be using a Makita router.
