About how much filament would be needed? to print all parts for the LR3?
[quote=“Printables.com”]
Looking at about 2.2kg for a full sheet build’s worth or prints,
[/quote]
So says the comments from the Printables repository for LowRider 3 files.
Some of that is a little variable, A smaller build might need fewer braces, hose hooks, etc. If you don’t want or need an LCD case, that also changes things.
If you are going with milled XZ plates, that reduces the amount by quite a bit as well, but if you are going to try printed YZ plates, that will increase the amount.
But 2.2kg is a good starting point.
