So nothing too fancy here.. I was impressed by a couple things though. This is my first lowrider v4 project and my first project using AI design. I connected opus 5.5 to fusion 360 and told it my requirements and the crappy leftover pine strip dimensions and MDF thickness and it just went off and designed the whole thing, setup the dogbones and the tabs, picked the mill from my library and generated the code in about 30 minutes. Ran the cut and was disturbed by how aggressive it was but the low rider did the whole thing in under 10 minutes and it came out perfectly. I was never able to get curls like this with my V2, mdf always used to create the worst dust storm. So yeah.. like an hour from idea to holding the pieces in my hand.
I just sent it without even checking how it setup the CNC.. looking back at the fusion file looks like 6mm depth passes at 3200mm/min.. I had my dewalt set to lowest speed. Mill was single flute 1/4" diameter.
The grooves are just shallow indicators for what angle to drill the holes.. I wound up making a template with those angles and manually drilling holes that depth and angle on each piece. I took some metal rod and gouged it up with an angle grinder and used a jb-weld knockoff to glue it in the hole. I also made a notch in each post with the angle grinder to catch the pegboard. Seems to be holding well.
I put this up 9 years ago and is still working well. I do need to put a center support for the longer one so I could add some more spools in the center. The design used 8x10 metal shelf brackets with 3d printed parts to connect the 3/4" EMT pipe to them.
Gluing roughened rod into angled holes is a neat way to hide the mounting. Out of curiosity, did the AI-generated job put the tabs and dogbones where you’d have put them yourself, or did you change anything before the next cut?
It put some thought into it.. the dog bones were perfect.. it also manually placed the tabs. I just used the code it generated but in hindsight I would place the tabs in less visible spots but to be fair I probably would have forgot about that too. I usually have to spend hours fiddling with fusion to get my cnc setup right and even then I wind up forgetting something half the time.
I think so.. I tried everything on my old V2 not sure if it wasn’t rigid enough or there was something in my old software setup limiting the speed but it’s so nice not having to deal with the cloud of dust.
