Can you tell me if I’m on the right track.
I need to pocket 25.4mm Mdf 15mm deep pocket.
I initially had 3mm passes using speeds/feeds of 20mms/16000rpm. These parameters are from the endmill bit recommendations.
Is that a bit high or should the speed/feeds/rpm be set lower/higher.
I’m using a 6mm, 32mm long 1F upcut for the pockets and 25.4mm profile cuts.
Does all of the above parameters sound about right?
