Fancypants Push Stick with Replaceable Stick
My trusty table saw helped quite a bit with my LR3 build, pre-cutting struts, fast and accurate pieces of Ryan’s torsion box table, and even being a handy table to stack all the pieces.
It was feeling neglected, so to honor it, I made it a fancy push stick, out of some pretty nice oak plywood scrap.
Found the olde tyme saw handle SVG file in some dark corner of the internet, and designed a replaceable “blade”. The smaller handle was the first wood cut on my new lr3, worked fantastic, but was a little too small for my hand. 30 seconds later it was resized to my exact hand dimensions, gotta love CAD! Finished the job on a little router table.
This thing will be a joy to use, feels perfect in my hand! Maybe I’ll make a saw…
-Will
(Happy to share it, just need to clean up the DXF a bit. EstlCam manual vector tracing sure is handy!)
I just love the cool hint to classical handsaw :slight_smile:
I never felt very confident or secure with push-sticks though, ever since I printed a “Grrr-ripper” clone, I only use this at te table saw and router table, it’s so much more secure :slight_smile:
Did you print Doug’s?
That’s really nice, and I’d be happy to make one if you share. :wink:
Probably not, didn’t know he made one, I’ll check…
I printed this a few years ago already: Push Block by Trobinou - Thingiverse
I love my grrrripper etc, but sometimes I find this style is handy. Plus one can never have too many push sticks!
I might make a little caddy that holds it on the fence for convenience.
I’ll definitely get the cleaned up DXF up on printables soon.
I should probably make a nicer one. I always just grab a scrap of 1/4" plywood and rip one out on the bandsaw when the current one gets destroyed.
I need to go find the 3d print for the gripper clone. I keep looking at buying one of those.
Mine is a remix of that one.
https://www.printables.com/model/123802-push-block-v4-threaded-inserts-edition-no-supports
this is cool!
Found one that combines a lot of mods and uses M5 screws. I think I am going to print this one:
Would love to get a copy of this, once your happy with the clean up.
Philip
Here you go! I put the “pockets” and “part outlines” (and “hole” which I helical drilled) on separate layers in the DXF.
https://www.printables.com/model/737251-classic-saw-handle-with-replaceable-push-stick-cnc
Have fun! Would love to see your versions. Perhaps a fancy wood for the handle…
It looks awesome. Thanks for sharing the files.
its the paw print for me!
Also will it cut a dove tail :eyes:
I have an OEM Gripper and it always feel a little sketchy. It is designed to run your hand over the top of the blade. I barely use it
I’ve had a couple pretty much since they were invented. They revolutionised TS safety IMHO, particularly when cutting small pieces.
I wouldn’t use them for cutting sheet materials, but the way they control material on both sides of the blade makes any sort of kickback impossible.
I don’t particularly enjoy having my hand over the blade, but I can’t think of why it’s unsafe, providing you have the blade set less than the height of the grrrippers of course. On the other hand I have had two “scares” using push sticks, both my fault - one where after the cut I accidentally dropped the end of the stick into the still spinning blade. Let’s just say I was lucky that time.
Table saws require 110% concentration!
