Hello - I have a MPCNC (used to cut steel, aluminum, etc if you know mine
) and I’d like to attach this "Creality 3D Titan Direct Drive Extruder 300° " to it.
My MPCNC is setup with the SKR Pro V1.2, with the “V1CNC_SkrPro_Dual_2209-” firmware, I believe.
I would assume that the extruder would be connected via the E2, as it’s free on the board. However, is the firmware setup for that? I would assume I would need different firmware for that, like editing it to use the E2 for the extruder.
I’d like it to still be able to use my router for it too, which I would assume it would still be able to use when it doesn’t call to use the extruder.
Any help would be appreciated!
Thank you
