EV Ownership
@Ryan Following on from the EV discussion in the CCJ thread:
We’ve been a primarily EV household for 12 years now and an EV only household for 5. 2011 Nissan Leaf purchased in early 2014 that has now done a bit over 100,000km and a 2021 Tesla Model 3 SR+ that was purchased in early 2021 and has done 60,000km. Not huge distances by American standards but in line with the median yearly travel distance for New Zealanders of 10-12,000km/year, with a couple of low spots due to working overseas, COVID and then a few years of working from home.
Both cars have been great. The Leaf is at 45% battery now so she’s pretty tired but can still do my 32km/20 mile round trip commute easily enough. 2-3% capacity loss per year is about expected with the Leaf, unfortunately, but newer EVs do a lot better. The Tesla is at around 90% battery reported which tracks with an initial drop and then stabilisation that’s common to Lithium Iron Phosphate battery packs.
If you want to go super cost effective, I’m a massive fan of the Nissan Leaf. Their batteries not holding up well means they don’t make good cars for longer distances but if you do 40-60 miles/70-100 km a day they’re amazing. Nothing too major in terms of issues, they don’t mind cheap tires, there were a ton of them sold, they’ve depreciated to being super cheap and they’re a lot larger than they look, especially with the rear seats down. Our 2011 Leaf is my go-to for having to pick up larger things vs the model 3.
We get around 140Wh/km or 270Wh/mi, add 10% overhead for charging losses and you’re at roughly 3 miles per kWh from the wall. If you’re on off-peak of 25c/kWh then that’s about 8-9c/mile for energy. At $4.50/gal that’s equivalent to getting 50mpg. That may not seem ‘that’ great, but that’s without needing to worry about flooring it away from the lights or during highway merges etc. Compared to the real-life experience of getting 50mpg out of many other cars, it’s dramatically different. Cost can be cheaper if you can do stuff like use any free charging nearby, charge off solar, charge at work, etc. Tires can be a bit more expensive if you go for low rolling resistance or EV specific ones, but given the relatively small difference it makes in reality (2-3% at most), for a commuter vehicle I’d personally just go with something decent and middle of the range, then just keep the inflation up. A lot of EVs, especially the earlier ones, do seem to respond well to slightly higher tire pressures. Not just better range due to lower rolling resistance but better contact patch and better stopping distances, I suspect because they’re typically a couple hundred kg heavier than the petrol/mild hybrid equivalents.
In terms of maintenance with our Leaf, other than tires, cabin air filter and windscreen wipers there’s not much. The single-speed reduction gearbox has ATF in it that should be replaced every ~40-60k miles but that’s pretty easy, it’s much more like a conventional diff than a gearbox oil replacement. I had an on-board charger die which is a ‘somewhat’ common issue with the 2011-2012 Leafs. That’s a case of unbolting the rear seats, pinching off the coolant lines under the car and taking them off the barbs, unplugging connectors, unbolting the charger and then doing the reverse for a 2nd hand or refurbed unit. Probably less than an hour if you’re keen. Other than that, I’ve had a window switch die, I’ve done the brake fluid a couple of times just for the sake of it, greased door hinges and that’s about it. It’s still on the original brake pads and rotors with tons of life left in them.
I think in terms looking back how things have changed for us going to EVs, there’s a pretty wide range of differences, some obvious and some more subtle.
The biggest difference for me is one that’s not really ‘that’ obvious until you look back at it. Coming from an Audi A4 wagon with some minor mods the Leaf is, in a real world/usable sense, significantly quicker and has higher performance. That’s not to say the Audi wouldn’t outrun it to 150km/h or beat it away from the lights if you launched the hell out of it, but actually driving the Leaf is like having a car that’s always in launch mode at every set of lights and driving it like a hoon uses maybe 10-20% more energy, not 2-3x more petrol like the Audi did. Repeated launching a DSG is a good way to lead to expensive gearbox work. Even my fiance likes blowing people away at traffic lights in the Leaf, amusingly. Being able to actually use the capabilities of the car without constantly wondering if that was going to be the final straw that causes some expensive repair is a nice feeling.
An obvious one is the lack of maintenance, but I guess it’s less obvious because I didn’t think of oil changes, doing brakes, gearbox changes as ‘that’ big of a deal to do myself. In reality it’s probably 2-4 hours a year that it saves, but the mental load of it being gone is huge, along with in reality it wasn’t just a couple of hours to do an oil change, that was usually the ‘one thing’ I’d do with that day due to motivation. Now, once a year I give the vehicle a 15 minute once-over before it goes in for its yearly mechanical inspection (Warrant of Fitness here in NZ). That mostly consists of making sure the wheel nuts are tight, the tires have tread, nothing’s squeaking or loose, the brakes feel good, no rust, brake fluid/coolant is where it should be, that kind of thing.
A less obvious one is charging. Both EVs have cables hanging in the right place that you can just grab them and plug them in as soon as you’re parked, one car in the garage, one car out in an off-street park. It’s maybe ~10-15s to plug in or unplug before you leave. Compared to 5 minutes at a gas station every other week, even though I used to drive straight past a gas station on my way home every day I think the plugging in and unplugging is actually more convenient.
The Leaf was also a lot cheaper in yearly registration costs and insurance than the Audi, the model 3 is about the same.
Another slightly oddball advantage for us is that by using a 12V inverter we were able to keep the house running while we had a 10 day power cut during some horrendous storms last year. That was definitely eye opening in terms of when you’re used to a tree coming down being a 4-6 hour power cut at worst, you don’t necessarily extrapolate that to consider what happens when a hundred trees come down at once and the damage is more severe. The stub we’re on only powers ~10-15 houses so we were way down the priority list and basically had an extra week of power cut simply because someone needed to reinstall the fuses for the pole-top transformer. Obviously there are a ton of ways to approach this, but a 2kW 12V inverter and then just leaving the car on and in ‘ready to drive’ mode worked really well. We’d get an entire day out of the battery then could drive 10 minutes to the nearest fast charger, wait there for half an hour to top it up and then drive back. No noise, could leave the car in the garage without worrying about asphyxiating ourselves, overall cost was maybe $5-10 a day for the fast charging, probably about on par with a generator and no dealing with the maintenance of a generator etc. Have used that approach probably a dozen times now in varying situations, including all-day maintenance outages while working from home. It’s great.
Oh man, I spent a good hour poking around our used EV market… I am interested and need to keep and eye on things. Looks to be a few power company incentives as well. At ~50mpg I might break even pretty quick.
Thanks for all that info, it helps bring it all into perspective.
It’s definitely worth shopping around power companies to see what the deals are but I always caution people that it needs to be a ‘whole bill’ consideration, especially if you’re not doing ‘that’ many kms in the EV.
Here there are some providers with really low overnight rates but correspondingly higher day rates. My fiance is home all day and we have quite a lot of ‘always on’ loads so the money saved on overnight loads don’t go far enough to offset the higher daytime rates, etc.
Same thing with stuff like solar buyback prices, we have some providers offering 12c/kWh instead of the industry standard 8c/kWh, but with higher import rates so you’d have to have a crazy export to import ratio to make it financially make sense.
Something like a Shelly EM or other whole-house energy monitoring setup can make that process a lot simpler.
Sing out if you have any questions. As I’ve said before, I live and breathe this stuff. EVs and charging systems have been my career for 15 years and it’s a personal passion, as well. I’m not as familiar with what’s available over there in the US as you guys have a few cars that we don’t get here but also you miss out on a lot of the Chinese brands that have rapidly become leaders in the space.
It’s definitely something where you can break even remarkably quickly. In the first years of owning my Leaf I was driving ~12,000km just commuting and at 3c/km for electricity rather than 30c/km for petrol, it was saving me a bit over $3,000 a year. Add onto that the ~$200-300 a year I was spending on oil, filters, etc. and it pays for itself damn quickly. At this point, ~80,000km later, I think that probably saved me ~$10k over its lifespan, assuming I just drove it off a pier and was comparing it to a car that somehow miraculously hadn’t depreciated at all in that same time.
The A4 I had cost me $30k NZD and the Leaf cost me $18K NZD. The Leaf is now worth maybe $1-2k at best which seems brutal, depreciation wise, but looking at prices for 2008 A4 Wagons, there are 2 selling near me for $4k asking, so it’s really not ‘that’ bad!
Oh, I forgot to mention one thing that comes up over and over again with EV owners: No brake dust build up on your wheels. It’s a small thing but oh man does it make washing a car just that little bit nicer…
Holy :poop:
CAD$0.08/km for me.
CAD$0.16/kWh.
Yeah, there’s a lot that can go into that, of course. NZD vs CAD is a 1.2 factor right there. NZ tends to have a relatively old and fuel inefficient fleet so even though our vehicles are smaller, the median vehicle here may not actually be ‘that’ much more fuel efficient.
Also, it’s straight up just one of the disadvantages of living on a small island in the middle of nowhere, relatively. Things cost a lot more, we don’t even refine locally here anymore and import petrol/diesel directly (although I think there are good reasons behind that and supported that choice).
And then the elephant in the room is that the oil industry is probably the single most subsidized industry on the planet. You may only pay ~$3/gal at the pump while we’re paying $10/gal but that’s also getting paid for in a bunch of other ways such as tax breaks, military/security presence, environmental regulation carveouts, straight up production/refinement subsidies, preferential purchase agreements, all sorts. A quick google shows $1.5T of overt subsidies in 2022 worldwide and a potential estimate of $7T indirect subsidies etc. We just tend to be the end purchaser so we don’t get as directly involved in those…
Edit: On the other hand, we have tended to have relatively cheap electricity due to some huge hydro and geothermal projects from days past, although a lack of infrastructure spending is starting to come home to roost a little bit. For us it’s about NZ17c/kWh overnight and 25c/kWh peak.
We have a Kia niro, it has been awesome til we hit 100,000 miles. It cost us 3500 for a new cat converter that they run antifreeze over (for heat) that started leaking!!! And now the ac is broke and needs another 3200. It went from a car I could not say enough good things about to a car I would not recommend. Kia knows of both problems but is providing NO assistance with either. It is really nice having a hybrid though. I wonder if we had bought a Prius if we would have been further ahead! Just spending the premium but having no problems at 100k miles. I really like hybrid over electric.
I’ve driven a few priuses and they really leave me cold as a driving experience. A friend has a prius that he uses for everything and I personally think the combo of a Leaf that I enjoy driving much more for around town and then a cheap petrol vehicle for taking out of town was a better fit at similar up-front cost.
Hybrid has it’s place but the niches where it makes more sense are dwindling by the day. They tend to have all the issues of a petrol vehicle in terms of maintenance and repair needs but also the downside of a poorly specified EV in terms of a small battery that gets cycled hard and dies young. It’s a meme in NZ that the entire taxi fleet is comprised of shagged priuses and every one of them basically isn’t a hybrid anymore due to the battery being poked. It’s a lot cheaper to replace a prius battery, for sure, but even the humble Leafs will mostly have 1 battery during their lifespans while my friends prius is on battery #3
Personally, I wouldn’t touch one with a very long pole. I get the desire for them but the overwhelming majority of people I talk to who have gone EV would never look back. VERY few people go ‘I wish I’d bough a hybrid instead…’.
Edit: Also, if you’re ever in a taxi prius, ask them what mileage they get. It’s pretty common to see 6-7L/100km here in NZ, despite their supposed 4.5L/100km rating. My friends gets around 5.5L/100km with careful driving so that’s 14c/km. I was spending 3c/km in my Leaf (now 10c/km with per-km road tax) while driving it like I stole it.
Seeing this made me do the math.. Roughly $0.17-.18 / Mile for me. Of course that’s without a trailer hooked up. Not doing that math :rofl:
Living in Michigan electric is not practical for winter. Heat costs battery!
Yet tons of people drive EVs in northern Europe… How strange.
Almost identical then with currency conversion. That’s mildly horrifying given that we pay ~2-2.5x as much for petrol, lol.
How far is the commute I do 120 miles a day minimum. It is 7 F. Yuck would they be fezable.
120 miles is pretty doable, plenty of EVs out there that get twice that under reasonable conditions. I’m not as familiar with how they perform under extremely cold conditions but a quick google showed my a video from a guy Iowa Tesla Guy who says ~20-30% range drop.
So it’ll probably depend. If you’re starting from a not-super-cold garage then average pack temp won’t be what the outdoor temp is. Starting with 300 miles of range, that’d probably work out but would also likely depend on whether you can charge once you get to wherever you’re going which would make it super easy as it’s only 2x 60mi trips or whether you’re parked in a parking garage with higher temps etc.
Also, if it’s anything like here, households tend to have multiple cars. I started out with an EV for commuting and a longer range EV for going out of town to visit family. Maybe that ends up being the case where presumably you don’t have 2 cars that are doing 120mi every day so maybe it’s 9 months of the year an EV and then 3 months of the year it gets swapped and the other household member has the EV for shorter trips.
But I’m about 80% sure that question wasn’t asked in good faith, anyway :wink:
Thank you for the answer I haven’t looked to much till just recently. It is because of the 120 miles a day and cost i am interested. Iowa is only 4.5 hrs away frome me. I’m from Mason City Iowa originally still a little family there. With 2 cars one a EV one gas the cold for gasses 3 to 4 weeks of cold and the rest EV may be doable :smiley: unfortunately no garage
Lets be clear though, we are for sure not comparing apples to apples. I spend that in a crew cab 1 ton dually truck that weighs in around 10k pounds. I would venture to guess you are doing that with something close to half the weight and 2 less tires on the ground.
My apologies for assuming that comment was in bad faith! In the EV groups we get a lot of people trying to justify why EVs can never work for their situation and it’s almost always something exaggerated to get a rise out of people. (Edit: And to be fair there are also a lot of people quick to assert that EVs can work for every situation. I tend to be a bit more of a middle-of-the-road pragmatist in that sense, at least by EV enthusiast standards!)
Man, those temps with no garage must be rough. On the bright side, all the EVs I’m aware of have the ability to be pre-heated while still on charge so you’d be starting with a warm vehicle and 100% charge.
The nice thing about that situation is that you’ll get plenty of warning whether it works for you or not if you do decide to try an EV. As the temperatures drop you’ll start getting home with less and less battery % remaining which will be a good early warning sign. If you get to a situation where you’re at 20F and it’s barely making it, you’ll have your answer without getting stranded. If you did want to try it in 7F you could go out of your way to put an extra 10-20% into the battery at a fast charger and see what you get home with. If you put in 20% and get home with 30% you’d have been fine. If you put in 20% and get home with 10%, you’d have run flat, for instance.
I really like the combination of an EV and a petrol vehicle for most people as it means the EV doesn’t have to meet every single use case. We started with the Leaf for commuting which was 80% of my actual driving and then a cheap petrol car for long ranges and towing. Now I’ve got the 2nd EV that does the long ranges and towing and my fiance has the old EV. Similar thing where my coworker has an EV and a people-mover. The EV for commuting and the people-mover for anything kid related. Or people who get an EV for most driving but keep a diesel pickup for towing the boat/caravan or doing hardware store runs, etc. Seems like that approach could work well for you.
That’s at least partially my point. Those vehicles just simply do not exist over here and we seem to get by just fine :slight_smile:
For sure. I wasnt trying to say anything against your cost or views on EV what so ever. I just had never taken the time to figure out “cost per mile” and when I saw your post it made me curious.
I don’t doubt that one bit. Different areas have different needs/use cases. An EV in their current state of tech would never work for what all I use my truck for. But I can very much see that its a perfect solution for many people whose needs are much different than mine.
Yea at 5 am its a little nippy to step out without autostart. At 20 degrees it will be closer to 8 or 9 weeks with gas
