I’ve been playing around with estlcam 10 and trying to figure out how to successfully carve out a picture like the below. Basically, I want the inside cut out and all the islands inside flush with the top of the wood, similar to if you were to use a fill tool - everything that is filled inside I want to discard. I use the hole tool to highlight the outer edge, then it my lack of knowledge kicks in, because I’m not sure of of what to select, so it becomes a big mess of pockets and islands.
