Estlcam plasma cutter settings
hi
I’ve set my mpcnc low rider 2 up to be used as a cnc plasma cutter. im just after some basic settings in estlcam. ive got the plasma turning on and off but when I do a cut it leaves about 10mm of material still on the sheet. and it also if the plasma starting up to soon and cutting.
any help would be awesome
cheers brett
have you tried to use the lead in feature?
pause on start p4. y have succes whit estlecam settings are you using grbl
[quote=“propain, post:3, topic:19736”]
estlcam cnc stering spindel motor delay
